  • SN95 4.6L Mustang Tech
Pinging at idle
  • Thread starter Thread starter Team Ford
  • Start date Start date May 21, 2006
Team Ford
109
  • May 21, 2006
If I lug my car or sometimes just taking off from a light I hear the car diesel or ping off idle or under load at very low RPM's. Any ideas on what might be causing this? I typically run 93 octane.
Dan_Soprano
7,410
54
129
Jacksonville, FL
May 21, 2006
  • May 21, 2006
Exhaust leak maybe?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 21, 2006
  • May 21, 2006
Or possibly loose heat shields on cats.
stng
182
  • May 21, 2006
It could be an exhaust leak, or something rattling like mentioned above. Are you sure it is pinging? All cars can potentially ping if you are luging it under a load, but not by just taking off. Does it make the same noise in the upper rpms? I am inclined to believe that if it is pinging that easily than it should also ping in the high rpms as well. If it is truly pinging and not something else then maybe you need to back off some of the timing with SCT2. What do you have your timing set at? If you have been running the SCT2 tune for awhile with no problems and this is a new development you could have potentially just have gotten some bad gas. Is you CEL coming on? Another thing that could be, is that if you drive the car pretty conservative potentially you could have carbon build up on the top of the pistons that is increasing your compression thus causing the pinging. You could seafoam it just to eliminate this possibility, I mean its a long shot but its a cheap thing to try.
Team Ford
109
  • Nov 1, 2006
I know this is an old thread but I just wanted to say I had to add +5 fuel accross the board and I was also able to add +2 degrees of timing. No pinging and it feels like I gained some torque back.
stangGT97
1,299
Boston area, MA
Nov 1, 2006
  • Nov 1, 2006
Thanks for the update man, glad to hear you got the issues worked out
BooWFO
991
Louisville, KY
Nov 1, 2006
  • Nov 1, 2006
Ok why not just pull some timing?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Nov 2, 2006
  • Nov 2, 2006
I noticed you have a sct2.. I had the exact same issue and I had to do the same to fix it on my old car. I wonder if we had the same canned tune.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
  • Gulftown980x
  • Jul 29, 2026
squeak93
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
