  • SN95 4.6L Mustang Tech
Pinging badly
  • Thread starter Thread starter 98Black4.6
  • Start date Start date Aug 1, 2005
First Prev 2 of 2
T
tjm73
2,418
Rush, NY
Aug 12, 2005
#21
  • Aug 12, 2005
  • #21
My 98GT was pingin liek crazy even at highway speeds when you gave it just a touch of throttle to go up a hill or pass someone. I just put a new O2 sensor (had a CEL) and it doesn't ping at all now.
CanadaStang
2,093
Mb
Aug 12, 2005
#22
  • Aug 12, 2005
  • #22
forpit2000gt said:
with the PI head swap the pinging should have done nothing but get worse, by increasing compression.
He's talking about just replacing the cracked intake, not the complete headswap.
9
98Black4.6
18
#23
  • Aug 13, 2005
  • #23
CanadaStang said:
That's good to hear!! Did you put it on yourself?
Yup.
9
98Black4.6
18
#24
  • Aug 13, 2005
  • #24
I though about that, but I do not have a CEL. And if it is the O2's, then something is causing them to go bad, which is the root of my problem. The H-pipe I am swapping in will allow me to rule them off the list if it still pings after installation.
9
98GT-AllMine
24
Space Coast, FL
Aug 18, 2005
#25
  • Aug 18, 2005
  • #25
I'll put my money on a "dirty" MAF sensor.
Experienced the same symptoms (clatter on WOT, no horsepower). Cleaned the MAF with contact cleaner, and now she runs like the proverbial "Raped Ape"!
K
k8037
watauga,texas
Aug 18, 2005
#26
  • Aug 18, 2005
  • #26
carbon buildup in egr port can cause an accel. ping. take the egr valve off and inspect the port if buldup is present clean it & install egr valve .my wifes 94 cougar 4.6l had the same problem & that fixed it. also the correct way to clean the maf is take it off & spray the wires w/carb. cleaner do not touch the wires.
First Prev 2 of 2
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
  • Gulftown980x
  • Jul 29, 2026
squeak93
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
