pinion?
  • Thread starter Thread starter 873Stang
  • Start date Start date Nov 21, 2007
873Stang
221
riverside
Nov 21, 2007
  • Nov 21, 2007
took my driveshaft off today and there is oil coming out from the pinion where the big bolt is, is this the pinion seal???
R
rossford
  • Nov 21, 2007
sounds like, easy fix,just dont over tighten nut,check for bearing problem,20 year old car
rockytoohot
48
  • Nov 21, 2007
Sounds like the oil is leaking through the splines on the pinion gear. I would remove the flange, replace the seal while your there and put some silicone on the splines where the flange goes on. This will cure your problem.
D
Power steering to rack and pinion bolt
  • Demigxd
  • May 21, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 21, 2026
Demigxd
D
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
2005 - 2009 Specific Tech Jun 18, 2026
TPony
