Please read!!!!! Engine running kinda rough!!!
  • Thread starter Thread starter AnthonyR23
  • Start date Start date Mar 24, 2007
AnthonyR23
661
Ontario
Mar 24, 2007
  • Mar 24, 2007
Here is what I have done:
Battery relocation
3 G alternator upgrade - I upgraded the main power wire ran it to the solonoid with a 2 gauge battery wire!! Kinda overkill, but should I have a fuse in there... or is it ok to go direct.. seems to be running ok...
Underdrive pulleys
Mark 8 electric fan.... I'm able to maintain about 200 degrees for my operating temp.. with a 180 degree thermostate.. fan turns on high at 160 degrees... so everything is good there..
BBK equal length ceramic coated headers... I have been hearing a ticking/squeeking for about 1 year and a bit from the passenger side.. and when I took of the exhaust there was a few rust holes in the original header... Definetely has got rid of that load squeek/ticking when car is under load.. but I can still hear it and the car seems to be running a little rough... has been sitting all winter .. but still it just doesn't sound right..
So for a little the car was kinda reving up and down especially at startup it would rev up.. so I gave the throttle body a good cleaning and the Air Control pump thing on the side which were both caked up with carbon etc.. I reset the computer by unplugging the bat. for about half an hour and tried adjusting the throttle set screw a bit with the Air control thing unplugged.. but the car doesn't seem to be able to idle much lower than 1700 rpm.. ... is that weird???
I have to get my hands on a meter to check that upper thing on the throttle body with the green wire to make sure it is at .98 or .99 I think or something like that.. Have to read a bit.
Sorry about the long post... just not sure what to do next... kinda still hear that ticking... could it be the clutch... my dad and I just replaced it a few years ago... or valves????
The car is still speed density... so I have to get to that mass air sometime... any ideas about what I should do next??? I will get some pics... Would it be worth it to replace the lifters... valves.. valve springs,, etc.. or should I do the mass air next... was thinking of getting a cold air intake with adapter for speed density......
I have a bit of extra money!!! That lovely income tax check came in.. but really not sure what to do next...
I will get some pics on... beware car needs a new top and paint...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 24, 2007
  • Mar 24, 2007
engine runs rough
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
poor idle
See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=534062
for help with your idle problems. The first post contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
Rear mounted battery ground wiring. Follow this plan and you will have zero
ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot
on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the
rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean
shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to
the chassis ground where the battery was mounted up front. Use a 5/16” bolt
and bolt down the 4 gauge engine to chassis ground, make sure that it the metal
around the bolt is clean & shiny. This is the alternator power ground.
The computer has a dedicated power ground wire with a cylindrical quick connect
(about 2 ½”long by 1” diameter. It comes out of the wiring harness near the
ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground
in the same place as you bolted the alternator power ground. This is an
absolute don’t overlook it item for EFI cars
Note: The quick disconnect may have fallen victim to damage or removal by
a previous owner. However, it is still of utmost importance that the black/green
wires have a high quality ground..
Picture courtesy timewarped1972
Crimp or even better, solder the lugs on the all the wire. The local auto stereo
shop will have them if the auto parts store doesn't. Use some heat shrink tubing
to cover the lugs and make things look nice.
AnthonyR23
661
Ontario
Mar 24, 2007
  • Mar 24, 2007
Serious Paint job needed!!!
AnthonyR23
661
Ontario
Mar 24, 2007
  • Mar 24, 2007
My car is a 88 still speed density!
AnthonyR23
661
Ontario
Mar 24, 2007
  • Mar 24, 2007
I am going to pic up that 3 digit code reader... Is it under the dash that I check the codes... hard to get at?? What exactly am I checking... There isn't any check engine light coming on... should the car be running?? or not?? kinda confused at what I should expect?? Is there any more info on how to use code reader..???
About the battery in the trunk.. I have both the lines mounted to a shinny spot under the hood, one from the block, one from the comp... and the battery negative is mounted to a shinny spot in the trunk.. Under the hood I just used the original wires that where there for the ground. and the negative in the trunk I just used the supplied wires and followed the instructions that came with the relocation kit from mustangs unlimited.. The positive is just run directly to the solenoid with the 2 guage battery wire that was supplied... The only thing that I didn't do is run a wire from the trunk up to under the hood for the negative.. is that necessary because it didn't say to do that in the kit..
AnthonyR23
661
Ontario
Mar 24, 2007
  • Mar 24, 2007
about the idle problem.... that check list for idle problems doesn't neccessarily cover if it is normal for my car to not be able to idle below about 1700 rpm...
AnthonyR23
661
Ontario
Mar 24, 2007
  • Mar 24, 2007
here's another pic
AnthonyR23
661
Ontario
Mar 24, 2007
  • Mar 24, 2007
Are my pics showing up...???
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 24, 2007
  • Mar 24, 2007
code reader diagnostic connector
Hint: the paper clip is $29.95 cheaper than the code reader...
AnthonyR23
661
Ontario
Mar 24, 2007
#10
  • Mar 24, 2007
  • #10
Help!!! lol
AnthonyR23
661
Ontario
Mar 24, 2007
#11
  • Mar 24, 2007
  • #11
Ok,, paper clip it is!!!! So should if I check each point with a meter/paper clip I will post the readings with and without the engine running... hopefully that helps...
Any other suggestions???
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 24, 2007
#12
  • Mar 24, 2007
  • #12
Follow the instructions I posted eariler. Jumper the self test ground to the self test input. Do not jumper any other connections.
Watch the check engine light and count the flashes. It wil flash 1, short pause, 1, another pause and then flash the codes stored in the computer.
It will require a little mental effort to group the flashes so that you get the right codes. If you have any doubts, then do spend the extra $ for the code reader.
AnthonyR23
661
Ontario
Mar 24, 2007
#13
  • Mar 24, 2007
  • #13
Car on or off.... does it matter????? for test.. I just wired up a little test light.... and am out in the garage right now...
AnthonyR23
661
Ontario
Mar 24, 2007
#14
  • Mar 24, 2007
  • #14
I just turned the key to on, didn't start the car though..... and cleared the computer codes. Then tested the fuel pump circuit and it seems to work fine.. made a noise.....
stockhatch
536
polar sloth country
Mar 24, 2007
#15
  • Mar 24, 2007
  • #15
My 88 made a squeaky/chirpy noise under load and I swapped headers, checked and checked for exhaust leaks, used a stethoscope looking for engine noises, etc. It sounded exactly like metal to metal contact, so I also swapped motor mounts thinking my equal length headers were hitting the frame. Turns out it was a blown head gasket that was chirping/squeaking out compression under load. I found it after it got so bad coolant ran down the block. The car ran flawlessly until right at the end when it finally developed an intermittent miss. A factory head bolt had broken off in the block allowing the head to lift and gasket to go. Hope thats not your problem....
AnthonyR23
661
Ontario
Mar 24, 2007
#16
  • Mar 24, 2007
  • #16
Ya hopefully its not that... I replaced my motor mounts too for some extra clearance.. I will definetely watch out for that... could be the problem....... thanks
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
  • Mindseye007
  • Aug 16, 2026
Mindseye007
