  • 1994 - 1995 Specific Tech
power steering problem?
  • Thread starter Thread starter Blackened302
  • Start date Start date May 19, 2007
Blackened302
1,439
South TX
May 19, 2007
  • May 19, 2007
i've noticed that whenever i'm pulling into a parking space, if i turn my steering wheel while i'm not moving/idle, the car will stall and die.
if i want to turn the wheel while not moving/idle, i have to give it some gas.
could this be a bad power steering pump?
the fluid level is full, so i'm not sure that is the problem.
thanks, gents.
True 5.0
237
Southeastern Wisconsin
May 19, 2007
  • May 19, 2007
It sounds like the spool valve in the steering rack is going. I'd like to hear what others think.
R
RAD
167
  • May 19, 2007
thanks, gents.
same problem here
Blackened302
1,439
South TX
May 20, 2007
  • May 20, 2007
ttt
T
tjh566
608
Northern Va
May 20, 2007
  • May 20, 2007
I get the same thing everyonce and awhile, but usually only in reverse for some reason.
Therian
The Highlander
Waterloo, Ontario
May 20, 2007
  • May 20, 2007
I remember other threads about this a while back, and while I don't recally the solution, I remember it being quite common.
My car did the same thing. I'm getting a remanufactured rack tuesday and should have everything running by next weekend. I'll report back if my problem went away. if it doesn't, I'd say it's the pump
Blackened302
1,439
South TX
May 20, 2007
  • May 20, 2007
cool, thanks Duncan.
another factor i'm unsure of is the new cam--it's pretty lopey, but the idle is set to around 850rpm... don't know if that's too low for the power steering at idle problem.
parchisi
519
New Mexico
May 20, 2007
  • May 20, 2007
I get the same thing. Figured it was just normal and since my car doesn't idle very smoothly, a little resistance would make it stall a bit.
Venom351R
4,548
41
98
MAINE
May 20, 2007
  • May 20, 2007
Thats strange my car does that to. At first I thought it was the cam being a PITA but then I thought it could be the fuel pump b/c my car wants to die stall and not run when it gets to a 1/4 tank and below but when I fill up it only takes 7.5-11.4 gallons to fill it up then it runs fine. Other times when its full or has pleantly of gas it will still stall out at times when at idle or a stop, it usually seems to be when Im turning as well.
Im only thinking it could be the power steering is b/c I have a small drip coming from that area. Its dripping down in front of the drivers side tire, its not oil and looks a lot like PS fluid. Perhaps its my PS pump and a fuel pump causing my problems?
Blackened302
1,439
South TX
May 20, 2007
#10
  • May 20, 2007
  • #10
^^hehe, i'm having the same issue w/ the fuel--i think the sending unit in the pump is bad, though, causing the fuel guage to read inaccurately.
i guess the p/s problem isn't so bad because the car runs, it's just annoying and i'd like to fix it so there'll be one less thing off the "why i hate my car" list.
hollywoodstang
1,095
May 20, 2007
#11
  • May 20, 2007
  • #11
it turned out to be my powersteering hose leaking. had same problem. Go get new power steering pump and hose, replace those 2 and you will not have that problems again for long time. if you don't want to buy new pump check your steering oil level and refill often, new pump (AGR performance) cost $100, and steering hose from FORD cost$100 (WTF!!!!!!IT"S A HOSE!!!whatever...) letting you all know. hope this fixes it and that was my solution.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 21, 2007
#12
  • May 21, 2007
  • #12
My car used to do that alot, then I cleaned my IAC. I think it has happened once since then,
HISSIN50
34
129
May 21, 2007
#13
  • May 21, 2007
  • #13
FWIW, 5.0's don't have idle compensation for PS (unlike some smaller engines which do). A low or lumpy idle just might do it.
I've learned to not turn the wheel while stationary (which is hard on PS anyhow).
Blackened302
1,439
South TX
May 21, 2007
#14
  • May 21, 2007
  • #14
i should've mentioned that i busted the p/s hose during the engine swap (along w/ the a/c hose, too, hehehe) so i have a new one.
iac is new, too.
i guess aside from getting a new p/s pump, i'll just have to live with it--i need injectors and breaks before i get a p/s pump. only problem i'm having is it dying while turning at idle, so guess i can push it down the list.
thanks, gents.
94-302-vert
1,947
NE CT
May 21, 2007
#15
  • May 21, 2007
  • #15
Up the idle a bit...
Actually what if you have the A/C on.. does it still do it?
The problem is that the P/S creates a VERY large sudden drag on the engine... so at idle with no warning (other input) the car jsut dies... smaller cars (ie half engines, or 4 cyl engines) often have a pressure actuated switch to detect when the wheel is turned and electronically open teh iac to give the engine a little more power and keep it from dying...
due to a low idle and lopey cam you probably are just not making enough power at those RPMs to allow the engine to recover in time...
Venom351R
4,548
41
98
MAINE
May 21, 2007
#16
  • May 21, 2007
  • #16
well Im kind of at a loss for what exactly my problem is b/c I appear to have a power steering pump leak (probably from a hose) but my issue also sounds like it could be the sending unit in the fuel tank. The pump is a walbro 255lph with only 15,000 on it so it could possibly be the sending unit in the tank. The car has 66,000 on it so I guess its possible that it could be gone although my last Mustang a 95 GT had 131,000 on it and I never replaced the sending unit.
Venom351R
4,548
41
98
MAINE
May 21, 2007
#17
  • May 21, 2007
  • #17
Im going to have the PS issue checked out this week and if that does not solve my problem then the sending unit is my next move.
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
