Power Steering
  • Thread starter Thread starter chrua
  • Start date Start date Oct 2, 2005
C
chrua
  • Oct 2, 2005
The power stering on my 67 is leaking majorly. I was wondering where common places for leaks to happen at and how hard it is to fix. And i know it isnt my pump leaking.
68 Coop
104
Mesquite, NV
Oct 3, 2005
  • Oct 3, 2005
Check the rack and pinion, probably there or the line connections.
Big_B
121
Sacramento
Oct 3, 2005
  • Oct 3, 2005
Two major locations of leaks (besides the pump) are at the control valve and the ram. Both are rebuildable, however extreme caution has to used while removing the control valve. Do not use a pickle fork on the stud, it will tear apart the sleeve inside and complicate things immensely.
If you have the cash you can buy a new control valve, the ram on the other hand isn't too expensive. Find out exactly where the leak is coming from before you do anything though - could just be an old hose.
yeloxr7
429
  • Oct 3, 2005
Most leaks are caused by old hoses. Replacements are not that expensive.
Check hoses first, then the control valve and ram.
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
A
90 Fox Manuel steering
  • adimice
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 2, 2026
Bullitt347
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
