Pressure plate question.
  • Thread starter Thread starter Edster
  • Start date Start date Dec 20, 2008
Edster
500
League City, Texas
Dec 20, 2008
  • Dec 20, 2008
Will a pressure plate for an'86 5.0 fit a flywheel for a '66 289?
Are ther certain later years that will work for the early style flywheels? BTW doesn't the flywheel for a 66 call for a 10 inch clutch?
rbohm
6,698
550
204
tucson,az
Dec 20, 2008
  • Dec 20, 2008
no. ford changed the bolt pattern on the pressure plates in the early 70's. the base pressure plate for the 289 was a 10" clutch, but you can put a 10.5" clutch on the 157 tooth flywheel. if you want something larger though you will have to step up to the 164 tooth flywheel.
N
Nosboss
115
  • Dec 20, 2008
I was able to use a flywheel out of an '84 on my 1990 roller motor that was in my '66 coupe. I went this route because I was able to use my early clutch with the newer flywheel. The 84 flywheel has the old clutch bolt pattern and the newer 50oz counterweight. I can't tell you any other years that work, but I know that one will. I am thinking the '83 is the same but not for sure.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 20, 2008
  • Dec 20, 2008
You can also have your flywheel drilled/taped at a machine shop for the different clutch disk diamete. Just make sure you don't use the later model flywheel on your early model motor or you will do some serious damage to it.
rbohm
6,698
550
204
tucson,az
Dec 21, 2008
  • Dec 21, 2008
if you do this, make absolutely sure everything is done perfectly otherwise you will have a severe vibration. there are flywheels that have both bolt patterns already on the flywheel. i think all after market flywheels are drilled thus.
Edster
500
League City, Texas
Dec 21, 2008
  • Dec 21, 2008
Thanks for the answers. I'm not drillin anything as it sounds like I'll save a few bucks but wind up spending way more later on.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 21, 2008
  • Dec 21, 2008
Thats why I said to have it done at a machine shop instead of doing it yourself. I also wouldn't trust Joe machine shop. A good race shop can do this for a reasonable price but you have to find one you trust.
67rcks
373
Dec 23, 2008
  • Dec 23, 2008
speed shop guys start to talk at $100, and you have no warranty it will be done correctly. At this price I would go for an aftermarket plate with holes for both wheels, or would not touch it.
rbohm
6,698
550
204
tucson,az
Dec 23, 2008
  • Dec 23, 2008
best way to go imo.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 23, 2008
#10
  • Dec 23, 2008
  • #10
I was figuring for 1hr of labor at a machine shop. Get an aftermarket flywheel for sure.
Edster
500
League City, Texas
Dec 24, 2008
#11
  • Dec 24, 2008
  • #11
I'm just gonna get the right pressure plate as I already have the flywheel.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
D
Pressure plate problems
  • david66
  • Feb 26, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 27, 2025
Realmongo
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
