  • SN95 4.6L Mustang Tech
pro-chamber problems
  • Thread starter Thread starter Figment
  • Start date Start date Sep 4, 2006
F
Figment
94
Tampa Bay
Sep 4, 2006
  • Sep 4, 2006
i just installed my Pro-chamber(2 part) on my 04 gt. it seems to be shifted to the passangers side, causing it to hit the body on the pipe and the muffler(3 chambers).
anyone else have this problem, and is their a way to fix it
thanks
propellerhead
1,541
"but what's with the but shots?"
Sep 4, 2006
  • Sep 4, 2006
I'm not sure I understand your description. However, I've removed and reinstalled my Prochamber a few times. Start with everything loose. Tighten up the long pieces (legs) onto the exhaust manifold first. Then the chamber section to the legs. Then the catback to the chamber section. Basically, start from the front and work towards the back.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Sep 4, 2006
  • Sep 4, 2006
Did you aligne everything while finger tigen all the bolt, then tigten all the bolts? I had PC befor, and fit was excellent(although quality of construction was....decent)
R
RoadconeTuning
458
Upstate, SC
Sep 5, 2006
  • Sep 5, 2006
just adjust it till it fits.. mine used to get lose and rattle all the time... just crank down on it and if it bends then o well...
Mossberg
ATL, Shawty
Sep 5, 2006
  • Sep 5, 2006
The beauty of a prochamber install is the 3 piece design which allows great adjustability. Like these guys said, finger tighten the bolts and adjust the pipes until they line up correctly. Also before you fully tighten everything, jack up the pc close to the body.
'03GTinFLA
486
St. Petersburg, FL
Sep 5, 2006
  • Sep 5, 2006
Hey Figment, is that my old PC? It fit good for me. I hope it's just an adjustment problem. Honestly it worked great on my car.
Good luck man.
F
Figment
94
Tampa Bay
Sep 5, 2006
  • Sep 5, 2006
[QUOTE='03GTinFLA]Hey Figment, is that my old PC? It fit good for me. I hope it's just an adjustment problem. Honestly it worked great on my car.
Good luck man.[/QUOTE]
yep thats the one., i ran out of time to refit it. but i will try and ajust it a bit this weekend. but does it sound so good.
F
Figment
94
Tampa Bay
Sep 5, 2006
  • Sep 5, 2006
this one is an older 2 peice one
Mossberg
ATL, Shawty
Sep 6, 2006
  • Sep 6, 2006
O-I-C
Then it will be a little more difficult but still not impossible to get it to fit correctly.
F
Figment
94
Tampa Bay
Sep 9, 2006
#10
  • Sep 9, 2006
  • #10
thanks guys, i did loosen everything up and pried everything over. wasnt easy but i did get just enough room.
'03GTinFLA
486
St. Petersburg, FL
Sep 10, 2006
#11
  • Sep 10, 2006
  • #11
Glad to hear it worked for you.
TweekedGT
1,274
Alberta
Sep 10, 2006
#12
  • Sep 10, 2006
  • #12
Hmmm, mine must be really old, i have just a 1 piece.
fastangboi
My first set of nuts vibrated themselves off.
Jul 26, 2006
274
Slowville
Sep 10, 2006
#13
  • Sep 10, 2006
  • #13
ive got a Pypes 2pc X and every bolt is tight and i have exhaust leaks and the pass. side muffler hangs way lower. im no novice when it comes to turning wrench, ive loosened and retightened the pipes several times with the same result. still a faint leak and a Flow hangin low.
Im thinking on going LT and mac pro chamber mid pipe and keep my Flowmasters.
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
New here , too many cars and too many problems
  • spencergt66
  • Mar 19, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 21, 2026
spencergt66
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
