Problem Located-distributor will not come out. why?
  • Thread starter Thread starter accidentprone86
  • Start date Start date Dec 26, 2005
accidentprone86
189
Westminster Colorado
Dec 26, 2005
  • Dec 26, 2005
So Today in my troubleshooting process I bought a timing light.
I check my timing and it is running 21* retarded from my base of 16 advanced.
"Damn No wonder my car is running like hell this explains all the performance problems"
So i go to adjust the timing, I was going to take the distributor out and go up one tooth and adjust from there.
Well took the hold down off and tried to take it out. The thing will not budge!!
I even stood on the intake and the radiator support and pulled with all my might but the thing still will not budge!! I don’t know what to do.
First off, Obviously timing dos not adjust it self so what could have caused this? I am assuming what ever caused the timing to retard also is blocking the distributor in.
Secondly, how do I get it out?
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Dec 26, 2005
  • Dec 26, 2005
Adjust the timing as close to what you want, lock it down. Get the car up to operating temp, shut down and then try. Heat will usually help.
accidentprone86
189
Dec 26, 2005
  • Dec 26, 2005
The thing will not budge. The car was hot, I had to wear two layers of goves not to burn my elf.
The thing will not even twist.
What could have caused the problem?
bill302
2,131
alabama,gadsden
Dec 26, 2005
  • Dec 26, 2005
ya you don't to burn you'r elf, i wish i had an elf (LOL) just a little humor to cheer you up i know how it is when things dont work right.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 26, 2005
  • Dec 26, 2005
Well that explains it all, the noise was somethign really f'd up in there. Nothing a leakdown and compression check woudl have found. Sounds like the drive gear going to the cam went to crap and is locking it in there. Try to get someone to turn the motor over by hand while you try pulling it out. That is some odd ****.
P
PRO50SC
1,012
Olney, Maryland
Dec 26, 2005
  • Dec 26, 2005
Take some carb cleaner and spray it around the base and let it soak in. Aftermarket parts or stock? Why do you want to move the dist. one tooth. That shouldn't be necessary?
accidentprone86
189
Dec 26, 2005
  • Dec 26, 2005
Stock reman parts.
Well i wanted to move up one tooth because 21 degrees is a lot just to turn the distributer since it is already turned almost all the way to the advanced.
So you guys think the cam gear and the distibutor gear got out of alignment. Would I have to replace to Cam?
bill302
2,131
alabama,gadsden
Dec 26, 2005
  • Dec 26, 2005
maybe not the cam gear is alot harder steel than a dist. gear. i had same problem once you can twist the rotor button i believe to the right while tapping or pulling on distributor good luck.
bill302
2,131
alabama,gadsden
Dec 27, 2005
  • Dec 27, 2005
hey were you able to remove it and what did you do.
Black1987Stang
1,422
Jersey Shore
Dec 27, 2005
#10
  • Dec 27, 2005
  • #10
Thats a good idea...
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • brandyn200
  • Jun 20, 2026
AeroCoupe
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
