  • 1994 - 1995 Specific Tech
Problem Solved!!!!!
  • Thread starter Thread starter DFG 5OH
  • Start date Start date Sep 29, 2005
First Prev 2 of 2
HISSIN50
34
129
Sep 30, 2005
#21
  • Sep 30, 2005
  • #21
matthiasj said:
thanks squeeze, my balancer is starting to show rubber, so its time for a new one i think anyawys. How could i tell if its "slipped"?
If one manually sets the motor to TDC, look at the balancer. If it is reading way off, that is a sign. While timing, the marks can be way off too (does not sound as though that is it in your case Matt).
The elastomer starts to crack and can be like that for a bit before the outer ring starts spinning (high RPM's are often what break it completely loose and let it spin).
Oh yeah, on foxes IIRC, the SPOUT connector should show 1/3-2/3 (that is the spec) of the battery voltage when tested with a meter. That might be what your guy was getting at.
Good luck bud.
DougNuts
2,596
Georgetown Ky
Sep 30, 2005
#22
  • Sep 30, 2005
  • #22
I doubt a new spout will allow you to run any more timing than you're at now. My car is currently set at 7* of timing I believe. Don't worry about being stuck at 8*.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 30, 2005
#23
  • Sep 30, 2005
  • #23
matthiasj said:
he also adjusted the TPS, he said it wasnt exactly right...
Non adjustable on our cars unless he went into the puter. IIRC didn't I tell you to check the timing??
v6v8swap
113
Oklahoma
Sep 30, 2005
#24
  • Sep 30, 2005
  • #24
Glad to hear that you're on the right track Matt!! If the local Ford dealer doesn't have that SPOUT, try out www.stangparts.com. The business name is Mustang Parts Specialties, they mainly part out late model stangs. I'm sure they could help you out. That SPOUT, by the way, should read a short (terminal to terminal with it pulled out of the connector). Or, very low resistance (~0.1-1.0 ohms). Good Luck Man!!
Starman
78
#25
  • Sep 30, 2005
  • #25
SeventyMach1 said:
I don't know that it would be a cause here .... but BTW he's referring to the IAT (Intake Air Temp.) sensor.
ACT/IAT same thing
And why couldn't a bad one cause pinging?? I've seen it and read about it on tech forums helping in some instances over the past 6 or 7 years
DFG 5OH
1,341
Louisville, KY
Sep 30, 2005
#26
  • Sep 30, 2005
  • #26
well its still running good, i'm going to try to bump the timing one more time, see how it runs
First Prev 2 of 2
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
