Problem when I started my fox
  • Thread starter Thread starter Campeto
  • Start date Start date Mar 11, 2011
C
Campeto
  • Mar 11, 2011
Hi, I am from venezuela, i don`t speak or write english perfect, but i do my best. My problem whit my mustang 1991 is when i turn on the engine it`s started very well, but later around the 6 minutes or 10, the engine started to donw rpm and turn off, when this happened i press gas many time to try keep control over the engine to avoid turn off, this process stay long 5 minutes more o less and later the engine stabilize fine, this fault happen every time when turn on, other point, is when i going running and the fault appear the car down the speed making explosions, but when i turn on the air/co the car go back to run normally but later reduce speed againts, turn off the air acc recover strength againts, on off on off the acc and later the engine stabilize fine. I dont Know what happening. I changed all sensor and nothing.
Thank for you time, sorry for my english
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Mar 11, 2011
  • Mar 11, 2011
Here's a good page to start figuring it out.
http://www.stangnet.com/mustang-forums/698148-help-me-create-surging-idle-checklist.html
The codes may tell you what's wrong.
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Mar 12, 2011
  • Mar 12, 2011
make sure your fuel pump and pressure is good, also make sure to put a new fuel filter in the car. its always good to check that your getting good fuel and Air. you said you cleaned your MAF (air meter) so you should be on the right track
  • Mindseye007
  • Aug 16, 2026
Mindseye007
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • brandyn200
  • Jun 20, 2026
AeroCoupe
