  • SN95 4.6L Mustang Tech
Problems with PI heads
  • Thread starter Thread starter bdcardinal
  • Start date Start date Dec 19, 2004
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 19, 2004
  • Dec 19, 2004
i got a set of PI heads for really cheap. everything looked fine until i started to take them apart. here is what i found. it appears as though the motor ran out of oil and seized. i need to know if anyone who has experience machining these heads if this can be fixed.
http://www.geocities.com/bdcardinal/000_0124.JPG
http://www.geocities.com/bdcardinal/000_0145.JPG
http://www.geocities.com/bdcardinal/000_0146.JPG
http://www.geocities.com/bdcardinal/000_0147.JPG
http://www.geocities.com/bdcardinal/000_0148.JPG
http://www.geocities.com/bdcardinal/000_0158.JPG
http://www.geocities.com/bdcardinal/000_0159.JPG
http://www.geocities.com/bdcardinal/000_0160.JPG
http://www.geocities.com/bdcardinal/000_0161.JPG
http://www.geocities.com/bdcardinal/000_0162.JPG
http://www.geocities.com/bdcardinal/000_0163.JPG
http://www.geocities.com/bdcardinal/000_0164.JPG
i took a bunch of pictures of the heads. i have all the combustion chambers, and all the cam journals and caps. i really need help on this because i need to know if i can use these or are they useless and i have to try to get my money back from the guy on Ebay.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 19, 2004
  • Dec 19, 2004
i wouldn't even try, if it seized it overheated and cracked, don't even know how bad at that. i bet there is warpage too, try and get your money back, good luck.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 19, 2004
  • Dec 19, 2004
ttt
billyfe390
573
  • Dec 19, 2004
Send me a pic billyfe390@hotmail.com
Your links suck.
I am guessing you took the cams out and noticed the cam journals are a little rough looking. Thats normal but let me see some pics.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 19, 2004
  • Dec 19, 2004
sorry, first time making a webpage. fired off an email.
billyfe390
573
  • Dec 19, 2004
Yup they had an oiling problem at one time.
What I would do is see if you have a local machine shop that could line bore them because as they are now there done.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 19, 2004
  • Dec 19, 2004
thats what i figured. do u know what a machine shop would put in the heads to make them work. does someone make bearings that slip in? my boss said that similar problems on honda heads usually meant that the head gets tossed.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 19, 2004
  • Dec 19, 2004
im planning on getting new cams anyway, but im just worried, if the journals get line bored, the cams will sit lower. this is the first time ive dealt with maching OHC heads. anytime i did head work i either used new parts or it was a pushrod motor.
billyfe390
573
  • Dec 20, 2004
I was just thinking of that same thing. I think the best route for those is a line bore and bearings or new heads. I would ask this question on www.modulardepot.com .
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 20, 2004
#10
  • Dec 20, 2004
  • #10
i really wish ford had used bearings in their heads. it wouldve cost what $5 $10 a motor.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 20, 2004
#11
  • Dec 20, 2004
  • #11
I had the exact same problem happen to my Cougar when I bought it. Apparently the previous owner let it run low on oil and the Cam on the pass side head ceased up. Broke most of the rocker arms and scored up the journals pretty badly. I was told by a local machine shop that they could be fixed, but I decided to go to a set of PI heads regardless. One thing I did notice after I tore the engine down though, was that one of the valves made contact with one of the pistons, so you may want to take into consideration that you may have a bent valve or two on your hands as well.
Hopefully you didn’t pay a lot for them, but it may end up costing you a fair bit to have them fixed an inspected. You may or may not just be better off looking for another set and keeping these ones around for parts?
Progress Thread Nicholase "lights out" build- MotiV8 engine management
  • nicholase
  • Aug 10, 2024
  • 26 27 28
46K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Fox 89’ GT 331 stroker, Trickflow upper/lower, TF#3 Cam, stuffed with forged goodies.
  • 08GT500
  • Nov 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2025
08GT500
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
