Puzzled w fuel pressure!!
Alright, I know i asked about this before and I did what u guys thought it was, but no luck!! my fuel pressure is all the way at 70 psi!! everyone has told me I have a pinched return line so i swaped my fuel lines and i had exactly the same problem!! I took it to get dynoed and their computer said I was running really rich! Any ideas would be greatly appreciated, I have a brand new adj fuel pressure reg frm aeromotive!! and I even put it on my other mustang to make sure it works. I am reading the psi off a gauge on the rail and i also moved it to my other mustang to make sure it worked as well! I have an in tank bbk fuel pump 255lph. My mods are an eagle 347 stroker short block, tfs heads, holley intake, 30lb injectors, msd distributor. I would really appreciate it if u could help me thank you!!
Only thing that would cause that high of a fuel pressure. Fuel Pump, Fuel Lines, Fuel Regualtor. Rule out injectors because even if 1 was bad it would affect pressure. Did you replace fuel lines from rails to tank?
