Question on right distributor?
  • Thread starter Thread starter brett_d
  • Start date Start date Dec 6, 2005
brett_d
  • Dec 6, 2005
I have a 1981 duraspark 5.0 mustang. I'm in the process of swapping a roller motor into it. It has the .467 diameter distributor in it and I know that I have to swap out the iron gear for a steel. I read somewhere that the distributer may be too short and that they made two different ones for the 5.0's. Is this the right dist. or do I need another one. Is there a way to measure it and compare?
Thanks!!!
shttygtstang
978
  • Dec 6, 2005
flat tappet cam uses , differnt distributor than a roller motor. not shure urs is flat .....
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 6, 2005
  • Dec 6, 2005
An '81 is definitely not a roller. Also, the distributor lengths are not different between roller and flat cam engines; the difference is between carb and EFI distributors.
Try to get a Duraspark distributor from a parts store for an '85 GT with a manual trans. It may be really hard to find one, but for the cost of a steel gear you can get a rebuilt distributor and the gear already installed. Thats what I did.
brett_d
  • Dec 6, 2005
will the 81 duraspark ignition work with the 85 dist?
65ShelbyClone
4,675
38
119
Dec 6, 2005
  • Dec 6, 2005
Eh, I think it will.
brett_d
  • Dec 6, 2005
ok! I guess I'll Find out!
Thanks for the help!
65ShelbyClone
4,675
38
119
Dec 7, 2005
  • Dec 7, 2005
Good luck. I'm pretty sure that Duraspark = Duraspark as far as pickups and modules go. A rebuilt one with a steel gear shouldnt put you back more than $50 with echange. Do a search on how to identify a steel gear versus iron. Its not unusual for the average chain parts store to have an iron geared distributor in a box marked steel or the counter flunky will give you the wrong one. I had it happen and others have too.
Keep in mind that the '85 Mustang GT/5-speed was the only model AND the only year to have a carbed(Duraspark) roller cam engine. Thats why they can be hard to find.
TrophyHead
1,195
11
49
PA
Dec 8, 2005
  • Dec 8, 2005
Becareful with the gears on the dizzy. I was arguing with a salesperson for 10 mins that it wasnt a steel gear. Cast iron has a rough finish to it and little holes. As the steel gears are nice and smooth.
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
P
Engine Swapping EFI distributor for carb distributor- shaft length is different
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 21, 2024
pindude80
P
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
