Quick Story Of A Crippled Pony, New Donor Car And Some Swap Questions. Also, Introduction.
maverick31210
26
Alright, so a quick story on what happened. A couple of years ago, I picked up a 90 notch. Loved the car, was not a daily driver. Had plans for a build over time. Car had headers, full exhaust, gears, and a couple of other things...nothing too crazy. Anyway, one night this past December I slammed it into a center divider. It cracked both driver's side wheels and tweaked the front clip. The entire left side of the frame was tweaked, the K member, and the firewall was pushed back slightly. Not terrible on the firewall but enough to where the clutch will no longer engage. The thing is a pain in the ass to move around with a bent control arm and no clutch. I was super bummed as I'm sure you can tell. Oh well...:poo: happens, you make mistakes and you move on.
...So this coming weekend I will be bringing home a new Fox. It's a 92 hatch that has been sitting at the shop at work for about 2 years. Boss bought it with plans to build into a monster. So we tore the thing down...well halfway. Shortly after, business grew...fast. We moved into a new facility and the car was left in the old warehouse with no time to work on it. In the meanwhile, boss bought a :leghump:ing monster. A fully built, 91 notch clicking off 9s on a conservative tune. Well the time has come to clear out those old units and not renew the lease. That car is coming home to me. It's completely stock and was purchased from an overweight woman who never drove it. The plan is to swap all my goodies on to it.
Few questions I do have:
-The new car is an auto. I want to swap in my 5 spd. I have read and continue to read up on the procedure and someone always run into needing some sort of hard to find part. If I have a fully complete donor car, I should not have any issues right? I can use the drive shaft, cross member, etc...?
My old car is fully complete...only thing wrong with it is the damage to the front right hand wheel assembly and frame rail.
-My current exhaust...as far as I know, there should be no difference between the hatch and notch variants right? I have a set of BBK headers and full Magnaflow system that I would love to keep.
Any other tips appreciated.
  • Sponsors(?)
95BlueStallion
Drop into my dm’s gurrrrrl
5,707
3,317
214
Cedar Rapids, Iowa
www.goodreads.com
If the hatch is an LX, your exhaust is the same from front to back. You are also correct on all the swap parts, assuming nothing is damaged on the old car. You will need to swap computers, and the trans harness may be different and need to be swapped (for reverse lights, etc). I would also swap out the rear axle assembly as a whole unit so that you can keep the gears you had put in the notch. That will be a simple unbolt/bolt in and bleed brakes job.
modulistic
383
29
29
if everything on the donor car is in good shape, it will swap over. i ran into one problem when I did one... the clutch cable came out about an inch short. i got a quadrant with the three hooks and it worked well with the existing adjustable cable. you should probably replace the quad and cable anyways while in there. i dont know if they moved the firewall forward between the two years or what might have changed. this was going from an 89 to a 92.
modulistic
383
29
29
also, dont adjust the cable too tight, to where it is always part engaged. that will wear out the throwout bearing and engine thrust bearing.
maverick31210
26
Awesome...thanks guys! I have heard that it is not necessary to swap the computer? I mean no biggie if I have to, from what I remember that thing is pretty much plug and play.
...and yes, both cars are LXs.
maverick31210
26
Cool, shouldn't be too big of an issue. I'm just glad I have the spare car...I'd hate having to track all the miscellaneous parts down.
I also heard something about swapping the cluster out as well?
Can you ballpark how long the swap takes. I know it varies wildly from one instance to the next but you know....
modulistic
383
29
29
when i did it, the interior was already gutted. im not sure how far you have to rip the interior out to change the pedals. provided the exhaust on both cars arent rust welded together, and you have every part and tool you need... i could knock it out in 8hrs. any little thing could stop the show though.
Thread starter Similar threads Forum Replies Date
MikeROD16 Quick story i wrote just now. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
chepsk8 Wrapping up the Magazine story, a quick survey of Fox Brake upgrades needed ASAP Fox 5.0 Mustang Tech 12
J Fuel line quick connect Fox 5.0 Mustang Tech 8
T Quick trade The Welcome Wagon 7
S How can I get a vehicle service (OASIS) report quickly? 2015+ (S550) Mustang -General/Talk 4
79 Fox Fox Quick exhaust question! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
Red50Fox Drivetrain AOD quick connect / disconnect fittings Fox 5.0 Mustang Tech 4
M New to the forums and have a quick question The Welcome Wagon 0
Cool Beans For Sale 1968 Mustang Quick Ratio Steering Box Suspension 0
D 95 GTS - Fuel Pressure bleed down / How quick? 1994 - 1995 Specific Tech 4
O Just a quick hello The Welcome Wagon 1
Blown88GT SOLD Vortech FMU with Quick Disconnect Fuel Lines Engine and Power Adder 0
1SIKPNY Paint and Body quick question about the hatchback and notchback and convertible Fox 5.0 Mustang Tech 3
Blucifer99 Engine Quick valve lash and preload question hydraulic roller Fox 5.0 Mustang Tech 0
lxhatch91 bbk headers quick question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
9 Paint and Body [[Very Quick Tutorial]] How to Remove your REAR bumper. SN95 V6 Mustang Tech 0
C Fox Quick question reguarding pa pump 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
C Quick spoiler question, 98 Cobra. 1996 - 2004 SN95 Mustang -General/Talk- 0
7 83-86 Stang/Capri COUPE owners, need a quick measurement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
Rdub6 Progress Thread 2nd Fox Body ..... quick advice needed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 393
Dan42 Had A Quick Question?? Fox 5.0 Mustang Tech 2
E Quick Exhaust Question. SN95 V6 Mustang Tech 1
Mustang5L5 Suspension Quad Shocks: Don't Be So Quick To Remove Them Fox 5.0 Mustang Tech 15
S 2004 Ac Line Disconnects. 1996 - 2004 SN95 Mustang -General/Talk- 2
6 65 Mustang Quick Steer Rebuild Instructions 1965 - 1973 Classic Mustangs -General/Talk- 2
92Apocalypso Need A Quick Answer On Differences With Ball Joints And Control Arms After Doing 5 Lug Swap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
92Apocalypso Progress Thread Well. That Escalated Quickly. Time To Start A Build Thread.... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 32
92Apocalypso 1 Quick Question To Clarify Parking Brake Cable Needed.... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
James V Fox Got A New Alternator. Quick Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
H Quick Help - Tail Lights For My 83 Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
M Quick Help ! Exterior Color The Welcome Wagon 3
B Quick ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
R Quick Question. 2005 - 2014 S-197 Mustang -General/Talk- 10
gruvee87vertgt Quick Question-will V6 Sn95 Spindles Works For 5 Lug Swap? Fox 5.0 Mustang Tech 5
A Quick Fix Or More Complicated? 1965 - 1973 Classic Mustangs -General/Talk- 1
A Quick Fix Or More Complicated? 1965 - 1973 Classic Mustangs -General/Talk- 0
Sketchy_GT Need Help Quick 1996 - 2004 SN95 Mustang -General/Talk- 17
92Apocalypso Who Wants To Be Awesome And Take A Quick Photo Of Their Brake Light Switch And Do Me A Huge Solid! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
MustangGTorg Just A Quick "hello" The Welcome Wagon 4
T Quick Throttle Body Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
The Green GT Getting Ready To Put The Engine Back Together. Quick Question. 1994 - 1995 Specific Tech 6
Blown88GT SOLD Fmu Quick Disconnect Fuel Lines Engine and Power Adder 4
Blown88GT For Sale Vortech Fmu With Quick Disconnect Fuel Lines Engine and Power Adder 0
A Cooling System, Few Quick Questions 2.3L (N/A & Turbo) Tech 5
V Help With Quick Measurement? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
C Fox V8 Or V6 Turbo... Looking For 250-300hp Quick! & My Transmission Options 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
2 Engine Quick Timing Question Fox 5.0 Mustang Tech 6
C Quick Wiring Question 1996 - 2004 SN95 Mustang -General/Talk- 2
N Hello New Here And I Need Help Quick!! 2005 - 2009 Specific Tech 0
