Rack and Pinion?
All you do is undo the factory nuts...push the bolts thru the bushing and it'll pop loose...the rack has some play in it when those bolts are removed...it will hang down some so be careful...no tie rods or the like to undo...
Are you replacing the stock ones or putting in offset bushings??? I dont' think replacing the bushings necessitates an alignment though...
Should be tit.... :D
