  • 2.3L (N/A & Turbo) Tech
Rear disc brakes
  • Thread starter Thread starter 4turboho
  • Start date Start date Mar 11, 2009
4turboho
119
  • Mar 11, 2009
Got a 91 and Im putting a rear end from a turbocoupe in my car the car. Originally it a 4 cylinder but has the v8 brakes on front and will have rear disc in back....Question is, is tomorrow Im going to replace the MC and the power brake booster. What MC should I get that will work with no modifications and what brake booster should I go with? also if I dont change the rear diff out tomorrow will the new MC work with the drum brakes as well?
evintho
20+ Year Stangneter
Nov 12, 2003
683
246
73
Santa Rosa, CA.
Mar 12, 2009
  • Mar 12, 2009
I swapped a TC rear w/discs into mine. I used the master and booster out of a '95 Mustang GT/V6. Also, I don't see why your stock m/c wouldn't work with drums. You might have to install an adjustable prop valve, but you're gonna have to do that anyway when you run 4-wheel discs. All the info you'll need is right here.......................87-93 Mustang 5.0 Brake upgrade pages. Improve your 60-0 times!
4turboho
119
  • Mar 12, 2009
Im askin will the new MC work with the drum brakes.
evintho
20+ Year Stangneter
Nov 12, 2003
683
246
73
Santa Rosa, CA.
Mar 12, 2009
  • Mar 12, 2009
It should. You'll have a bigger bore size which means it's pumping a larger volume of fluid into the wheel cylinders, which means your pedal travel will be alot less, but I'm sure you'll get used to it.
4turboho
119
  • Mar 12, 2009
Thank you I do appreciate it
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
Brakes ATS brembos and drums
  • 5ptslow
  • Nov 16, 2025
Fox 5.0 Mustang Tech Apr 4, 2026
AeroCoupe
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
