Rebuild or New
  • Thread starter Thread starter Chairbornranger
  • Start date Start date Dec 22, 2008
C
Chairbornranger
  • Dec 22, 2008
I was wondering which would be better. Rebuild my stock rear end and add 3.73 gears or buy a direct bolt in 9in rearend.
I_AM_CANADIAN
189
B.C.
Dec 22, 2008
  • Dec 22, 2008
The nine inch will be more costly but has the advantage of being able to swap gears in half an hour for when you go to the drags
P
PAzYearazzUP
Banned
Dec 12, 2008
33
  • Dec 22, 2008
... Plus, you wasted all that money on the rebuild, you could have invested in the hardware you might probably resell once you rotate the race stock or what have you. I would not sent that money toward a rebuild when the 9 inch is penny wise is you are going to get it up the rear end no matter what gear oil you use is start with some fresh new parts back there is your worry about the rear end is over.
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
K
Engine rebuild in connecticut
  • Kngtmare
  • Aug 30, 2026
Potomus Pete
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
