  • 2005 - 2009 Specific Tech
Removing Adhesive From Door Panels
  • Thread starter Thread starter 37ford
  • Start date Start date Jul 14, 2012
37ford
35
MS
Jul 14, 2012
  • Jul 14, 2012
I'm one of the lucky owners who has door panel inserts that have given in to the heat. I've reglued them twice with poor results. I guess I did not use the right product, but it's too late now. They are just too caked up with adhesive that didn't work. I decided to just tear it all off, including the backer, and make an aluminum insert plate. There's a good surface back there if I can just get the adhesive off. Evidently, Ford used the worst glue to put on the vinyl and the best glue on earth to attach the backer to the door panel. I've tried lacquer thinner, xylol, naphtha, alcohol, brake cleaner, goo gone, and oops. Nothing has made a dent. The only I know left is the 3m stuff. I'm going to try to get some tonigh, but does anyone have any other suggestions?
streethorse
1,042
Dallas Texas
Jul 15, 2012
  • Jul 15, 2012
When I did mine the old adhesive / foam was dry.... came right off with a dry scotch bright pad, no liquid
at all, it just crumbled right off in seconds. I used contact cement and its still holding after 6 months.
tbar327
10
Vancouver BC
Jul 15, 2012
  • Jul 15, 2012
Try contact cement remover.
Interior and Upholstery Best vinyl adhesive for door panels?
  • wobbyguy
  • Jan 27, 2025
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 31, 2025
limp
Progress Thread 87' GT rescue
  • africansnowowl
  • Apr 29, 2020
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2020
Cheapskate207
H
Door Strike Replacement Issue (repost From The Tech Forum)
  • hhearst
  • Sep 4, 2012
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2012
gearheadboy
H
  • Locked
Door Strike Replacement Issue (shameless Reports From The Tech Forum)
  • hhearst
  • Sep 4, 2012
  • Locked
Aluminum "Premium" Dash Panels: Trade For BLACK?!?
  • stilbo
  • Apr 12, 2011
  • Interior Exterior Parts
2K
Interior Exterior Parts Jun 27, 2012
bryan95502
