replacing my fuel pump today
  • Thread starter Thread starter 90_stang_gt
  • Start date Start date Apr 16, 2004
9
90_stang_gt
  • Apr 16, 2004
how much of a pain in the a$$ am i getting in to??
9
90_stang_gt
  • Apr 16, 2004
ok i got the 2 straps off and am going to pick up my new one.... are those the only things holding the tank in???
lxsteed
1,009
Melbourne
Apr 16, 2004
  • Apr 16, 2004
Did you loosen the filler neck bolts? you'll have to wiggle that out of the way to drop the tank, then unplug the harness that runs to the pump, then you can drop the tank.
blkstangman88
646
  • Apr 16, 2004
doin the pump swap is very easy, but when i put the new 155 lph pump in i had to use a hack saw to cut like 3/4in of the metal pipe off and put in a new rubber hose, cuz the pump was longer then the stock. after the wires are unplugged and the filler neck loosed and the tanks on the ground just get like a flat head and a hammer to loosen the screw like ring and the sending unit and pump will have to be twisted and turned in a few directions to get it completaly out. very easy.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
  • brandyn200
  • Jun 20, 2026
AeroCoupe
