  • 2005 - 2009 Specific Tech
Roush suspension in
  • Thread starter Thread starter CPman
  • Start date Start date May 23, 2006
C
CPman
129
  • May 23, 2006
Took me a Saturday to install but is well worth the time and cash. The drop was noticable but not extreme, about a inch in the front and slighty more at the rear. The ride is just a little bit firmer than stock normal driving, but when pushed, it goes right where you point it. Best of all that most annoying front end clunk is gone. So far! I have one question of anyone else that has installed this kit. Did you get any instuctions, I did not, I'm wondering if Roush has alignment spec's of their own. or if I will need to install camber bolts. I would like to install these myself before taking it in for an alignment, if I need them.
LV51FER
318
Caerphilly, Wales, UK
Jun 30, 2006
  • Jun 30, 2006
If it helps (and it may not), I ordered springs from Roush here in the UK (to go on my Tokico D-Spec struts) and queried any suspension realignment and they said they hadn't done anything to theirs and the tyre wear was even. This was on a hard-used presss demonstrator but get it checked if I were you. They don't have any camber bolts on their price list.
krang00
79
Allentown, PA
Jun 30, 2006
  • Jun 30, 2006
I installed the roush springs all the way around and I agree, it's a much improved ride. A little stiffer but no rubbing issues with my 20 inch rims even when fully loaded. My friend and I have a Hunter alignment machine that we use for all our cars and when I put it on the rack it wasn't that far off. I installed an adjustable panhard bar but DID NOT need camber bolts for the front. I have camber set to about -1.2 with a slight toe-in and haven't had any issues. My wife and I just got back from a trip to VA beach which was about 700 miles round-trip and I didn't notice any issues. Time will tell if the tires wear evenly, but at this point things look good. FYI I also did BMR LCA's, and steeda end-links.
J
jack1.1
78
St. Louis, Missouri
Mar 8, 2007
  • Mar 8, 2007
call roush performance, they have specific alignment numbers for the "S2" or Roush suspension cars. They will fax you the sheet.
06BLR85
38
  • Mar 8, 2007
So this kit you installed is the same kit as on the stage 3. cuz thats what i want, a stage 3 roush without the body panels.
Oh and what about the brakes roush uses on the stage 3, anybody have those.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Mar 8, 2007
  • Mar 8, 2007
http://forums.stangnet.com/showpost.php?p=6373945&postcount=27
06BLR85
38
  • Mar 8, 2007
Thanks for the link, i should have just look there.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • dan50
  • Jul 18, 2026
dan50
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
