  • SN95 4.6L Mustang Tech
Rpms
  • Thread starter Thread starter 2vjordy
  • Start date Start date Sep 9, 2017
2vjordy
Active User
Jul 19, 2017
  • Sep 9, 2017
My mustang rpms is staying at 2200 and won't go no lower I undid my cables and touched them that's what I heard to do but that didn't work...any ideas if a sensor or something and what sensor it would be
imp
Mustang Master
Jul 13, 2017
531
105
83
Sep 9, 2017
  • Sep 9, 2017
Check for trouble codes. Consider stuck open Idle Air Control, or Throttle Plate (less likely). imp
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 10, 2017
  • Sep 10, 2017
+1 on above.
To add, how about a common garden variety vacuum leak? Or bad IAC valve?
Here's some more information on how to trouble shoot.
Troubleshoot IAC idle problems 1996-2004
https://www.stangnet.com/mustang-forums/resources/troubleshoot-iac-idle-problems-1996-2004.13/
It might be handy to mention the model year of your Mustang. But likely this won't change the trouble shooting steps.
Reactions: imp
2vjordy
Active User
Jul 19, 2017
  • Sep 11, 2017
I changed the iac and the idle is going back down now but when I drive and come to stop the rpms still wanna stay up for like 15 sec then goes down..do I have to do a idle re learn process or something ? Or was the valve not the fix I mean before I put the valve the rpms wouldn't go down at all now they do just takes like 15 sec
imp
Mustang Master
Jul 13, 2017
531
105
83
Sep 11, 2017
  • Sep 11, 2017
Starting to think vacuum leak some where, which PCM is still able to "overcome" in efforts to reach idle speed. imp
2vjordy
Active User
Jul 19, 2017
  • Sep 11, 2017
I'll check for a vacume leak tomorrow let you no how it goes thanks
Neuron
5 Year Member
Nov 6, 2016
859
192
93
Sep 12, 2017
  • Sep 12, 2017
My '98 did the same exact thing(replaced with Motorcraft Part) but settled down after a couple of days and worked fine after that, maybe had to relearn the PCM?
2vjordy
Active User
Jul 19, 2017
  • Sep 12, 2017
Does anyone no how to do a relearn process I heard you can let the car idle or something I'm not to sure
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 12, 2017
  • Sep 12, 2017
Does the car's speedometer work? Why does this matter? Because it is NORMAL for the PCM to keep the idle slightly higher while the car is moving. The PCM will only select slow idle when the car is stopped.
Search on hanging idle as 1,000's have complained about it. The trick here is to understand the difference between a normal hanging idle and an abnormal hanging idle.
A 2,000 RPM idle isn't likely normal.
A 1200-1500 RPM idle while moving is normal.
Bottom line: IF the RPM eventually settles down to a normal slow idle that means that the IAC is working and is being commanded by the PCM.
Did you review any of the information provided in the trouble shooting IAC/idle link? Did you perform the IAC basic functionality test?
Regarding the relearning process. Is the battery and alternator in tip top shape? Have you driven the car for several days? If both are true then a working PCM has had more than enough time to re-learn.
2vjordy
Active User
Jul 19, 2017
#10
  • Sep 12, 2017
  • #10
I haven't driven it for several days yet and the idle is still high like that when not moving at all and even when coming to a stop sign or red light it's never stayed that high before
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 12, 2017
#11
  • Sep 12, 2017
  • #11
Here's some information on an affordable Windows based ODB2 scanner. How can this help? With an ODB2 scanner it's possible to monitor the IAC duty cycle. A slight vacuum leak will show up as a lower than normal IAC duty cycle.
ForScan ODB2 scanner w ELM327 USB
https://www.stangnet.com/mustang-forums/resources/forscan-odb2-scanner-w-elm327-usb.57/
Or course having an ODB2 scanner will open up a world of other diagnostic information. Car repair will never be the same after you see what an ODB2 scanner really can do.
Reactions: imp
2vjordy
Active User
Jul 19, 2017
#12
  • Sep 12, 2017
  • #12
I will check that out thanks
TangStang
#13
  • Sep 21, 2017
  • #13
The PCM must relearn the IAC, but the TPS works in conjuction.
Check the output voltage. It should be no more than 1.0 volt.
These two sensors can fail together.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
  • Gulftown980x
  • Jul 29, 2026
squeak93
