  • SN95 4.6L Mustang Tech
running issues
  • Thread starter Thread starter cherrysmash
  • Start date Start date Apr 18, 2007
cherrysmash
Maryland
Apr 18, 2007
  • Apr 18, 2007
hi. i have a 02' GT 5-sp. with the following mods:
flowmaster A/T cat-back
bbk O/R X- Pipe
bbk MIL Eliminators
professional Products 75MM TB
Professional Products Plenum
American Thunder Plenum spacer
K&N cold air intake
C&L 85mm MAFS
March underdrive pulleys
when i'm driving on the hwy at about 50-55MPH in 5 th gear, the car bucks serverely and also if im in traffic for a long period of time on a warm day, the car loses a bunch of power. does anyone know what could be causing this? please help!!
D
Dragstr05
643
Stafford VA
Apr 18, 2007
  • Apr 18, 2007
If you're in 4th at 50-55, does it still buck? Trying to accelerate from 50mph in 5th puts alot of load on the engine which may just be upsetting the underlying problem.
Is the check engine light on? How many miles on the car? Were any of the mods recently done that could be contributing to the problem? On the sitting in traffic note, is the engine overheating? Any visible smoke or high fuel consumption?
Sorry for all the questions, but a yes or positive answer to any of these will help to better diagnose your problem.
cherrysmash
Maryland
Apr 18, 2007
  • Apr 18, 2007
re:re: running issues
no, it doesn't do it 4th. if i put a heavy load on it in 5th it will buck real hard until about 2000-2500RPM's and then it will smooth out. it throw codes for the o2 sensors (running lean in bank 1 and 2) once in a while, especially when idling for a long period of time. it doesn't overheat or anything. just after sitting in traffic for a long time, if a was to take off hard, it feels like it lost like 100hp, but if i drive it a good period of time(maybe 5min. or so) its back to normal. i also notice that the motor rocks a little in idle, and it sounds like it has a miss to it. the plugs are new. what do u think?
the98stang
2,408
Clovis, CA
Apr 18, 2007
  • Apr 18, 2007
definetely fix the o2's if the car is throwing codes. That's at least part of the problem.
D
Dragstr05
643
Stafford VA
Apr 18, 2007
  • Apr 18, 2007
The codes you have, plus the rough idle and "miss" all point to a vacuum leak. Start there. If both banks are running lean, that could explain the hesitation in 5th.
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
F
1993 Cobra flooding
  • FireFoxCobra_SVT93
  • May 20, 2022
6K
Fox 5.0 Mustang Tech Mar 11, 2023
nickyb
L
Engine What to do now?
  • LATT5133
  • Apr 2, 2021
2K
Fox 5.0 Mustang Tech Apr 4, 2021
Monkeybutt2000
M
A
1991 5.0 - fires up every time, idles perfectly, but once it’s warm it won’t idle for more than 15 seconds
  • Jul 27, 2021
  • 2 3
9K
Fox 5.0 Mustang Tech May 21, 2022
Mindseye007
