Sail panels....?
  • Thread starter Thread starter 85GTlover
  • Start date Start date Jun 22, 2004
85GTlover
704
  • Jun 22, 2004
Can someone tell me quick how they come off? I do not want to waste time if I do not have to , or break them if they are attached from inside. Please help asap.
dastang2
2,020
tx
Jun 22, 2004
  • Jun 22, 2004
if what you are refering to is the side panels of the body kit, you unscrew them from the bottom then pry it up.
85GTlover
704
  • Jun 22, 2004
I am refering to the plastic "fin type" things behind the windows. Is that what you mean? I never really looked yet, but noticed no screws at the bottom. Thanks.
dastang2
2,020
tx
Jun 22, 2004
  • Jun 22, 2004
oh sorry i thought you ment the side panels on the body kit
dastang2
2,020
tx
Jun 22, 2004
  • Jun 22, 2004
most likely you will have to take the inside panel that is around the back windows and then you will see screws as well as the nuts that hold the window in place
85GTlover
704
  • Jun 22, 2004
Thanks I kind of figured they were attached from inside, but I did not want to go through that process to find out they "clip on" or something. Thanks.
maverick0716
3,924
Chilliwack, BC, Canada
Jun 22, 2004
  • Jun 22, 2004
Yes, you have to take off the inside panels. I've done it to mine before.
Fox Block Decode
  • PonyGTrider
  • Jun 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
PonyGTrider
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
