Scored Some Staggered Pony Rs, What Size Tires?
deathb4dismount
Crap, didn’t realize my crotch was in that picture
5 Year Member
Oct 6, 2011
993
499
104
THE BUCKET
When you think you have a great deal there is always a but. Picked up some Pony Rs for $350 today. The wheels are in great shape.
Here is the but, though. On one of the ten inch wheels the holes for studs are oblonged. I'm not a wheel guy but I know that's not good. Let me know what you guys think.
  • Sponsors(?)
89ripper
145
40
Rockford, Illinois
I must be out of the loop but I have never heard nor seen "pony rs"
As far as the oblong hole im assuming you can still mount the tire on the car you are just concerned about what could happen if you do?
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,061
9,207
224
Massachusetts
Looks like someone had the lug nuts loose on that wheel, or they loosened up.
Since lugs use tapered seats, they should be ok. Of course might be better if someone looked at in in person. Might want to find a local wheel repair shop and see if they can clean it up a tad with some light machining. Better safe that sorry.
deathb4dismount
5 Year Member
Oct 6, 2011
993
499
104
THE BUCKET
They have been around for awhile. These are 17x10 and 17x8. These are the Mavromont ones which aren't sold anymore. Not sure if they are the same as the 50resto 17 inch ponys
deathb4dismount
5 Year Member
Oct 6, 2011
993
499
104
THE BUCKET
I just sent a picture to a friend of mine who used to work at a wheel shop. He said it looks like nothing to worry about but wants to check it out to be sure. I still can't believe I only paid 350 for these
89ripper
145
40
Rockford, Illinois
I used to follow and keep up with mustangs back before i had my son so that must be why i never seen them before. I agree about having a shop look at them first. Can't hurt
deathb4dismount
5 Year Member
Oct 6, 2011
993
499
104
THE BUCKET
I know Nittos run a little narrower so I was thinking 315/35/17, or would the 275 ET street s/s be a better fit? I prefer the rear tires to sit square but would rather have them bulge than stretch. What should I run up front? @TOOLOW91 , I believe you can help with this.
TOOLOW91
7,140
234
S.I.NY
I run 275/40 et street s/s and they are square but do let the lip of the wheel where the bead sits protrude a little bit. This seems to be a m/t thing as my buddies 03 cobra wheels did the same thing with the et street 2s on it .
The nittos in 275 sat flush to the lip but did run a little small so the side wall appeared to have a slight stretch vs being square
deathb4dismount
5 Year Member
Oct 6, 2011
993
499
104
THE BUCKET
Thanks man. I looked into the Toyo Proxes TQs and they seem to run a little wider than the Nitto 275 so I am going to try that. They are also the least expensive and supposed to have about the same tread life as the Nitto. If I go with 275/40 should I go 245/45 front?
TOOLOW91
7,140
234
S.I.NY
That's exactly what I run. I think it works well
revhead347
My mission is to out curmudgeon you
8,174
1,081
214
40
Acworth, GA
Looks like someone cross threaded an acorn nut once or twice. I wouldn't worry about it too much. Worst possible scenario is you will need to have a machinest touch up the taper.
Here is what I recommend. Buy a standard $2 disposable acorn nut. Lube up the the threads on the studs with oil. Mount the rims, and drive the nut down with an impact, full balls. The taper on the acorn will round out the taper on the wheel. Take them back off, clean everything up, and re-install with a torque wrench.
Kurt
Reactions: deathb4dismount
deathb4dismount
5 Year Member
Oct 6, 2011
993
499
104
THE BUCKET
Mocked up one of the wheels, and boy is it tight. The quads will definitely need to come off and probably some BFH work. I can't wait to get some big ol meats on them.
deathb4dismount
5 Year Member
Oct 6, 2011
993
499
104
THE BUCKET
Flip the quad. Should clear then
If I can flip them I will, probably going to buy some newer ones as these look to be the originals. First I have to take out a second mortgage to afford tires. They probably wont go on until next season.
Jersey Joe
I remember blowing that Monkey's ass
1,046
154
52
Bloomingdale N.j.
My quads are original and taking them off was a bitch, lots of PB blaster, breaker bar and a frigging pipe over that.
revhead347
8,174
1,081
214
40
Acworth, GA
Do they even make replacement quad shocks? I thought everyone just tossed them.
Kurt
Thread starter Similar threads Forum Replies Date
T Fox Scored a 5 speed feature car with only 67k original miles 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
JDSpeed Barn find score 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 61
John Dirks Jr Score At The Pick N Pull 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
poboys 94 Scored Some Gt40ps. Need Some Diy Direction Please. Fox 5.0 Mustang Tech 7
John Dirks Jr Ford Nats Parts Score 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
theYman Engine Scored Underdrive Pulleys Fox 5.0 Mustang Tech 21
John Dirks Jr Scored A Ford Racing Driveshaft 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
hoopty5.0 Score One More For Junkyard Motors. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 33
mikestang63 Latest Score Of Parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
cdurbin Craigslist Score! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 30
CarMichael Angelo Score! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 166
wicked400ex Coyote Engine Scored Cylinder Wall 2010 - 2014 Specific Tech 41
krisx125 Good score??? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
Adams91LX Scored some interior stuff today! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
TOOLOW91 150$ score 1996 - 2004 SN95 Mustang -General/Talk- 0
95Vert383AOD My July 4th SCORE (Top This) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
rd Score, I think Fox 5.0 Mustang Tech 1
tannerc91gt Scored a few deals tonight! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
nick6690 Scored a set of Cobra R's 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
M where to score front suspension bushings 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
281pony This weekends Craigslist score.. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
306notchback Scored 347 shortblock for $850 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
GroverDill Scored a deal. Pics 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 199
KXT Scored an '85 in a trade and need your help Fox 5.0 Mustang Tech 5
89GT331 Junkyard Jumping Scores (Explorer Int Found) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
S&B Parts score! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
C SCORE and need help with shelby style harness Classic Mustang Specific Tech 1
D Fuel Pump Eccentric Scored Timing Gear Cover? 1965 - 1973 Classic Mustangs -General/Talk- 3
B Ebay Score!!!! Saaahweet! Mach C's 1996 - 2004 SN95 Mustang -General/Talk- 7
onestripevert score 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
D Just Scored a 427FE Highriser for my 67 Classic Mustang Specific Tech 6
notchnut Where can I score some 42# injectors? 1996 - 2004 SN95 Mustang -General/Talk- 10
mustang50v8 I scored a great deal today!!! 1996 - 2004 SN95 Mustang -General/Talk- 6
L my $100 score 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
94GTLaserRC New Bowling HIGH SCORE....247!!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
1987Rock SCORE!! New shocks/struts/springs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
mixedbreed02gt Score!!!!! 1996 - 2004 SN95 Mustang -General/Talk- 4
black87ttop Good deals ive scored lately 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
RYC CUKR Scored a new interior for the 88 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
woodyy24 SCORE again!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
samickguy15 SCORE!!! Fox 5.0 Mustang Tech 8
woodyy24 Score!! " pics of score inside" 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
85_SS_302_Coupe I scored big at the junkyard! 2.3L (N/A & Turbo) Tech 6
Pearl02 Scored 2001 Bullitt Gauges Off Ebay 1996 - 2004 SN95 Mustang -General/Talk- 6
A Scored cams only right head SN95 4.6L Mustang Tech 15
K Check out what I scored for 10$ at the dragstrip! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
MAC'n89Blckstng Scored my dream job!!!! My summer has started off awesome. Pics inside! Dialup warnin 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
Roland69 scored a free aluminum drive shaft 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
5spd GT Scored this for $100 bucks... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
65ShelbyClone Did I score or strike out on this engine? Classic Mustang Specific Tech 18
