  • 1994 - 1995 Specific Tech
Scraping/Grinding Noise
  • Thread starter Thread starter JNeidlinger
  • Start date Start date Nov 3, 2007
J
JNeidlinger
31
  • Nov 3, 2007
Heres the issue. If my car is slightly heavy- (full tank of gas/passenger, etc), I will hear a scraping/grinding noise from the back of the car somewhere. It is difficult to locate while driving, but it is somewhere around the driveshaft/rear end. It will only make the sound while under acceleration. If I drive gingerly and accelerate slowly as to not let the rear suspension take a load, the sound wont happen. Once the car is at a constant speed, the sound stops.
The car is a 94 GT 5.0l, 5-speed. This problem is seeming to get worse, and I cant for the life of me figure out what it is. I cant make the sound happen when its at a stand still, on jacks. Any ideas?
HISSIN50
34
129
Nov 3, 2007
  • Nov 3, 2007
Probably the DS and E-brake bracket meeting eachother. It can also be the DS and muffler(s).
I use a guide coat of flat black paint on the places under the car that I think are rubbing. Paint it, take it for a drive and then come back and note where the paint is rubbed off. That's the interference spot.
Good luck.
GTA_V6_Mustang
1,326
Miami, FL
Nov 3, 2007
  • Nov 3, 2007
Hissin is right. One of the things you should look at is if the driveshaft is also meeting the chassis. because you might have a spring or control arm issue. This was happening to me for the longest time in my old mustang and one day I finally noticed it was the driveshaft rubbing against the chassis. Turned out I had ripped the rear passenger upper control arm where it mounts to the chassis right out, with a peice of the chassis.
DDSTANG94
465
FRASER, MICHIGAN
Nov 3, 2007
  • Nov 3, 2007
+1 .....had the same problem..I jack the car up and seen a wear mark on my muffler and ds...when the back off the car was "seating" it would rub it....
Adam95GT
2,564
Burlington, NJ
Nov 3, 2007
  • Nov 3, 2007
yea problem is solved...
J
JNeidlinger
31
  • Nov 4, 2007
Turns out it was the e-brake bracket. The rear part of the bracket, which looks to be spot welded onto the body is ripped from the metal it was welded to. It is being pulled/bent down by the tension of the brake cable, so that it is about 1/2" from the driveshaft. I can clearly see where it is grinding. Should be as simple as moving the driveshaft out of the way, bending the bracket back up, and welding it back to the body. Thanks all.
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Y
2004 Mustang GT AUTO (4R70W) Grinding noise when going in R or Drive does it as I put it into park too
  • yellowandblack
  • Dec 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 21, 2024
89ripper
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
