  • SN95 4.6L Mustang Tech
shocks/struts
  • Thread starter Thread starter Owned
  • Start date Start date Dec 25, 2004
O
Owned
104
  • Dec 25, 2004
whats a good combo of shocks and struts for a 2 inch drop, i was gonna go with some kyb g2 are these good? or the mach one/bullit combo maybe even the hp series. any imput would help
Edit' 300 and under would be great
N
narongc73
146
  • Dec 25, 2004
Kyb=cheap
Mach one's are better. Go with H&R's springs and Bilstein shocks/struts
ShadowGT
202
Western Kentucky
Dec 25, 2004
  • Dec 25, 2004
You could go with the Bullitt set up and throw in some Ford "F" lowering springs. That will get you close to 2".
BTW, you know if you drop that much you will have to replace your caster/camber plates as well?
ShadowGT
202
Western Kentucky
Dec 25, 2004
  • Dec 25, 2004
Edit: I'd go with the Mach set up and the "F" lowering springs. The Mach kit comes with sway bars, shocks/struts for around $299 (Bullitt kit has springs too and is $399). Since you want to lower it so much, you won't need the Bullitt springs.
The Ford "F" lowering springs are about $210.
You could probably leave your stock shocks/struts on for awhile and get the Ford "F" lowering springs and c/c plates for right at $300. That will get you the drop, but you stock shocks/struts will wear out quickly.
nickthegenius
1,631
Elwood, IN
Dec 25, 2004
  • Dec 25, 2004
GR-2s are OK if you are using stock springs. They'll blow out just as quickly as your stockers if you put lowering springs on them.
I've had H&R Supersports and Mach I shocks and struts for 1.5yrs and that is a great budget combo. $179 for the shock/strut set and $220 for the springs. Add $175 or so for C/C plates and you're all set.
BTW, the Supersports are advertised as something like 1.8"F/1.6"R and its more like a 2" all around once it settles a week or so after install.
GDawg
1,469
Nevada
Dec 25, 2004
  • Dec 25, 2004
Bilsteins are nice but you aren't going to get them for under $300... you'd be lucky to get them for under $500, I paid closer to $600 for all four.
N
narongc73
146
  • Dec 25, 2004
They have a lifetime warranty and the shocks/struts are rebuildable. It's worth it. I got them off ebay for 460 shipped new.
GDawg
1,469
Nevada
Dec 25, 2004
  • Dec 25, 2004
Definitely worth it, that's why I have them. Just saying they aren't cheap.
O
Owned
104
  • Dec 25, 2004
How do the Mach 1's do on the streets and the strip im leaning towards those
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 26, 2004
#10
  • Dec 26, 2004
  • #10
The Bilstein struts and shocks with the
H&R springs would be a great combo!
D
4.6L 4v motor swap
  • DangStitches
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
squeak93
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
