  • 1994 - 1995 Specific Tech
Side Emblems
  • Thread starter Thread starter smitty_64
  • Start date Start date Jul 21, 2006
smitty_64
75
  • Jul 21, 2006
Does anyone know what the easiest way to get the side emblems off is? I want to put my 347 Stroker emblems on.
R
RyClef331
118
Jacksonville,NC
Jul 21, 2006
  • Jul 21, 2006
heat gun....
It thats not a viable option then, I've used a flathead, covered with tape on the end. I've also seen heavy weight fishing line used as a "cable saw."
Davin
1,353
Jacksonville, FL
Jul 21, 2006
  • Jul 21, 2006
Yeah, heat gun, otherwise you'll have to do a bit o wet sending..just posted to show off my SWEET avitar side emblem!
Z
zZsKyZz
503
Jul 21, 2006
  • Jul 21, 2006
I used a heat gun set on low (you can also use a hair dryer) then use a plastic scraper... you don't want to fawk up your paintjob..heat and anything metal scraping will do that....keep away from them.
R
rockin_rick
968
Jul 21, 2006
  • Jul 21, 2006
I've used the fishing line 'saw' before without a heat gun and it works ok. Heat helps, though...
I think that I'd use a screwdriver (or whatever metal tool) as a last resort. Too easy to mess up and too hard to see just what's going on under there.
Rick
69clark
731
Ravena, NY
Jul 22, 2006
  • Jul 22, 2006
I have to remove emblems with the work I do with my business. The easiest and most effective way without doing damage is to use fish line or dental floss to saw or cut the tape. Once it is off you will have to pick (with your nails) the rest of the tape off. Clean area with alcohol and your done. You may have to double or triple up the fish line or floss so it doesn't break, but it works everytime, AS LONG AS IT ISN'T BOLTED ON! lol
ProKiller
3,064
15
78
PA
Jul 22, 2006
  • Jul 22, 2006
heat gun lightly going around in circles. you'll be there a while waiting for it to get hot, but the longer it takes to get hot, the less damage you'll do to the paint.
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
