  • SN95 4.6L Mustang Tech
Slight Electrical Issue any ideas?
  • Thread starter Thread starter tc3k101
  • Start date Start date Jun 25, 2009
tc3k101
11
  • Jun 25, 2009
Alright I will start off by saying what happened is entirely my fault. I was putting my interior back together started to put my dash back together and was plugging in my factory radio but forgot my car was in gear and key was turned(only way to get center console on) and plugged in the factory radio and heard a pop. Now my Speedometer does not work and niether does my factory radio or my unlock switch. now i know what you are thinking check the fuses, i did and they all check out under dash and hood.
my question is are there any inline fuses under the dash the i am not aware of? also when u hold the unlock switch the headlights come on as u press the switch? I feel so stupid for making such a petty mistake but it happens. any suggestions will not be taken lightly.
I do plan on taking it to one of my dealers i do work for and they are going to diagnose my car for free but that is for something else when we replaced the engine. seems i have a bad sensor or something. different story different day.
squeak93
2,319
396
164
Joplin, Missouri
Jun 25, 2009
  • Jun 25, 2009
Have you checked the big fuses/relays under the hood in the power distribution box?
tc3k101
11
  • Jun 26, 2009
yes i have, and everything checks out. I'm pretty much stumped at this point. hoping it is a easy fix maybe a wire loom or something but ugh who knows
Intercoledc6
25
  • Jun 28, 2009
Did you ground a power wire? what popped? it should not hurt anything to plug the radio in when car power is on... i dont want to scare you but when you hear a pop usually it is electrical component frying...
larry
ThePumpkin
55
Missouri
Jun 28, 2009
  • Jun 28, 2009
Use a test light or digital multimeter at each fuse. see if they all are getting power.
find whats not getting power and use a wiring diagram to track it down.
Just my .02
Good luck.
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
