smoke
  • Thread starter Thread starter blue87lx
  • Start date Start date Apr 29, 2005
blue87lx
175
  • Apr 29, 2005
when i rev my car to anywhere above 3 grand it backfires and puffs out alot of white smoke somone help?
sirr0bin
174
Winnipeg, Manitoba
Apr 29, 2005
  • Apr 29, 2005
have you checked your coolant lately?
lots of white smoke and backfiring sounds like headgasket to me
green
291
  • Apr 29, 2005
car could be getting to much fuel, and flooding
blue87lx
175
  • Apr 29, 2005
i just did the head gaskets last week and it was doing this before i done them. to much fuel is usually black so im still puzzled
UMDSmith
226
Salisbury, Maryland
Apr 29, 2005
  • Apr 29, 2005
white smoke normally = coolant
black = fuel
blueish = oil
You said you just replaced your head gasket, but check the coolant again. My gf's old Tbird blew headgasket after headgasket (ford's legendary 3.8 motor, aka the headgasket killer).
blue87lx
175
  • Apr 29, 2005
ok sew situation now... after actually getting to check it out in daylight it is smoking blue. it looks like there is a little oil seeping around the header gasket on #4 and the plug is covered to. the little bit of backfiring was the timing thats taken care of. so whats with the oil?
ALMOSTFINISHED
315
Westchester County NY
Apr 29, 2005
  • Apr 29, 2005
Sounds like the valve cover gaskets to me. Your best bet would be to clean off the entire area with brake clean or engine gunk, then ooce dried, let the engine run for a bit and keep an eye on where it was showing up, that will give you a better direction to head in when it comes to ordering the gaskets.
Nick
T
TbonesBlack92GT
25
  • Apr 29, 2005
White smoke typically signifies a lean condition.
blue87lx
175
  • Apr 29, 2005
the smoke is blue there is oil around the headrer where #4 cyl is not valve cover gaskets. oil on #4 plug
GREG91GT
207
MISSOURI
Apr 29, 2005
#10
  • Apr 29, 2005
  • #10
rings
Black 93 Fox
1,995
Vancouver,Washington
Apr 29, 2005
#11
  • Apr 29, 2005
  • #11
GREG91GT said:
rings
I kinda think the same thing
blue87lx
175
#12
  • May 1, 2005
  • #12
i ordered all my parts but are u sure white could also mean its running lean? my cats are gutted and i have speed density.. could this be it or am i looking at rings most likely?
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
