I'm having the same problem , i can jump start it and it will run fine , as soon as i turn it off the battery will be too dead to start it again , battery is brandnew.
Been alot of good advise on here, but I'll toss in a few things...
When you have batt drain probs, meters can only give you a guess as to where it's at.. Unless you want to take the time to properly disconnect the circuit, and reconnect to the meter.. Otherwise your grasping at straws, and you might get lucky.. Mostly because 1 fuse will power several circuits..
I used meters for yrs on things like this, but resently switched over to a amp clamp.. You can find them at Sear's I believe, they arnt cheap, but worth the price. And are useful for so many other things.. If you suspect the alt, put it on the batt cable going to the alt, if you get a draw, there ya go... Put it on the power wire for the interior circuits, if you have a draw, you narrowed it down to interior circuits, then you can go to the fuse box.... Doing that with a meter takes time... I've spent hrs with a meter tracking down amp draws, now I can normally find them within 5-10 mins..
The plus side for a amp clamp is you can even see what the starter draws, how many amps the alt is putting out, figuring out what size fuse you should use on a new circuit. You just simply put the jaws around the wire.... Meter's, most of them you are limited to 10 amps, thats not much and you have to disconnect the circuit and wire the meter in a series...
mine would die out after only a couple of mins of sitting at one point, i was leaving the track, had my battery disconnected all day so it wouldnt drain, pulled into the gas station, got gas, wouldnt start, i had to push start it
