  • SN95 4.6L Mustang Tech
sounds like a harley??
  • Thread starter Thread starter bigbird99
  • Start date Start date May 23, 2007
bigbird99
15
las vegas, nevada
May 23, 2007
  • May 23, 2007
i started my car today and heard a loud pop, then the car sounded like a harley. a very loud popping sound coming from the passenger side valve cover, right next to the throttle body. anyone experience this??
the98stang
2,408
Clovis, CA
May 23, 2007
  • May 23, 2007
Can you post a sound clip? Is it consistant with acceleration?
Nater
239
Maplewood, MN
May 23, 2007
  • May 23, 2007
Did you blow a spark plug through the head? Pull the plug wires or COP, depending on the year of the engine and see if there is a plug loose.
san~man
O-G
A little grass shack on a big lava rock
May 23, 2007
  • May 23, 2007
Sounds like you threw a plug...I hope not for your sake.
StangYellow
1,052
May 24, 2007
  • May 24, 2007
One pop? Repeated pops? The one pop could signal your spark plug possibly popping out of the threads which means $$$$. If its a repeated sound, you might have blown up a spark plug? Sometimes if you crack a plug, you will hear a really loud popping or knocking sound based on engine rpm. Hopefully its the plug and a couple bucks
bigbird99
15
las vegas, nevada
May 24, 2007
  • May 24, 2007
well, i towed her in and ford said i blew a spark plug. this same thing happened to my brother's 99 GT. is this a common problem? is there a any recall? this is the fourth incident that i have heard locally.
Nater
239
Maplewood, MN
May 24, 2007
  • May 24, 2007
No recall on it. There are a lot of people mad about it because it is frequent not only on the Mustangs but with other vehicles too. Time to upgrade!
W
w.neurauter
98
  • May 24, 2007
Does anyone know if the extended ford 75,000 mile warranty covers this?
merc123
420
North GA
May 24, 2007
  • May 24, 2007
Probably.
the98stang
2,408
Clovis, CA
May 24, 2007
#10
  • May 24, 2007
  • #10
God this really pisses me out off about Ford. Why in the HELL wouldn't they make a recall? Obviously it's not an uncommon thing.
We need to make a sticky on this topic. Everyone should torque down to 13lbs with little to minimal amounts of anti seize. Plugs should be checked every oil change. If everyone did this, we wouldn't have these blow out threads....
RedDaemon
3,470
9
108
Atlanta, GA
May 24, 2007
#11
  • May 24, 2007
  • #11
wouldnt you get a CEL if something like that happened?
twogts4us
4,188
12
79
Dunedin, FL
May 24, 2007
#12
  • May 24, 2007
  • #12
Would this prevent a spark plug from blowing out? I'm not questioning your post, I really dunno soi I'm asking. Has that been the issue - over-torquing?
the98stang
2,408
Clovis, CA
May 25, 2007
#13
  • May 25, 2007
  • #13
Yes, and no. If you are using the OLD motorcraft plug with the shorter threads, then chances are it will still blow out, even if you are torqing it down good. But if you use the new plugs, or another aftermarket brand, they will stay in there if you torque them to 13lbs. It is recommended to torque them between 7-14lbs, but I would have them tighter. I don't use anti seize either. The plugs come out fine.
bigbird99
15
las vegas, nevada
May 29, 2007
#14
  • May 29, 2007
  • #14
spark plug threads
is it true that the heads on 99' mustangs only have 2 threads holding them in??
also, if i upgrade to say, patriot stage II heads, do they have more than 2 threads?
smallstang393
75
#15
  • May 30, 2007
  • #15
Ford factory heads have a Aluminum 4 thread insert in them. Patriots have a 4 thread Steel insert in them and they have a upgrade 8 thread steel insert too
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Fog horn sound
  • brandon4v
  • Jun 22, 2026
SN95 4.6L Mustang Tech Jun 23, 2026
squeak93
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
