Spacer Dimensions
  • Thread starter Thread starter 65inworks
  • Start date Start date Dec 9, 2004
65inworks
101
sacramento,ca
Dec 9, 2004
  • Dec 9, 2004
I have a set of 17x8 bullits rims with an offset of 5.72 and i know that optimal backspacing on a 65 mustang is 4.75 so that means i need a 1 inch spacer. CORRECT? So with that being said that means i need a set of sheel studs that are one inch longer. RIGHT? any help is really appreciated, Thanks Nick
hotrodnut
672
North Florida
Dec 9, 2004
  • Dec 9, 2004
I would suggest if you are going as thick as a 1" spacer to use a hub-centric style adapter/spacer that will bolt to the existing lugs which has another set of lugs that you bolt the wheels to. M & M makes a nice spacer like this as do others.
The 1" longer stud has too much stretch to them when torqued and could possibly cause some problems. Also the 1" spacer that just has holes through it can not re-center the wheels as well as the hub-centric design, of course this is just my 2 cents worth . . . .
65inworks
101
sacramento,ca
Dec 9, 2004
  • Dec 9, 2004
I know that people are using bullit rims on their 65 mustang but i need to know what the spacer looks like, i have a set the bolts to the wheel studs and then it has a seperate set of studs that the rims bolt to, i have heard that these are not very strong in design, is this true?
allcarfan
The Answer Man
2,458
North Atlanta
Dec 9, 2004
  • Dec 9, 2004
The spacers you describe are exactly what you need. I run late model bullit wheels and have a 1" spacer. I didnt need any special lugs or lug nuts. Just bolt the spacer to your existing studs, then bolt the wheel to the spacers studs...viola...done. I had a big write up with pics on stangnet, but that was deleted months ago.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Fox In search of a Spec clutch dimension.
  • PonyGTrider
  • Jun 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 3, 2025
PonyGTrider
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
