  • 1994 - 1995 Specific Tech
spacer...
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Nov 19, 2006
MI95Cobra
451
Oklahoma City
Nov 19, 2006
  • Nov 19, 2006
i have an 1/2" spacer i want to put on my intake....but it has the tube connecting the headers to the intake.....how do i go about putting it on....
RIO5.0
6,892
N.H.
Nov 19, 2006
  • Nov 19, 2006
If your running the stock "crimped" tube you can pull a 1/2" lenght outta the crimping...Been there done that...
There are longer ones..I just so happen not to have a clue where...I'd rather stetch the mofo...Im cheap...
drakesdad
961
Oregon OHIO
Nov 19, 2006
  • Nov 19, 2006
We welded and ground it down for mine but I think 50 resto makes one....
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 19, 2006
  • Nov 19, 2006
If you get some 1/2" flexible copper tubing, you can make your own tube. I had to when I swapped my new engine in a couple months ago. Of course I didn't have much of a choice because I cracked the original tube trying to bend it to fit my intake. I cut the ends off the original tube so it'd seal correctly at both ends. Slip the cut off ends over the copper tube, slip a feril onto the tube, and tighten it down as you would normally once you bend the copper to suit your needs. Total time, about 10 minutes. Total price, like $2.50
MI95Cobra
451
Oklahoma City
Nov 20, 2006
  • Nov 20, 2006
thanks that helpful....either stretch excisting tubing or add on to it....sounds simple...
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
D
Throttle Body Spacer
  • dropteeth
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
nicholase
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
