  • SN95 4.6L Mustang Tech
Spark knock?
  • Thread starter Thread starter Dark_Horse
  • Start date Start date Oct 5, 2009
Dark_Horse
83
Springfield, MO
Oct 5, 2009
  • Oct 5, 2009
Over the last two trips to the drag strip, I’ve been noticing an issue with the motor on the top end – i.e. between 5K and 6K RPMS. It sounds like a popping or crackling noise which I can’t figure out. My initial thought was that it may be the alternator or one of the other bearings on the pulley system. My other thought was maybe it was a slight exhaust leak coming from the header to midpipe connection. Somebody on the other forums suggested that it might be spark knock, which I think may be the problem.
I’m running a stock 2V 4.6L setup with catless h-pipe and an SCT 93 tune and some octane boost. Last summer, I changed out the spark plugs and bought a set of used coils on eBay to replace the stock ones for really cheap. I did this as a preventative measure really. However if the problem is spark knock at high rpms, my first thought would be a bad coil or some fault in the ignition system.
So my question is this: what is spark knock and how do I identify it? Is there a way to test each of the coils for functionality? I have read tons of threads about keeping the stock coils because they work just as good as the MSD or Accel aftermarket ones. I don’t have an A/F gauge but I’m thinking of pulling the plugs just to see if any combustion problems exist. Is it possible I have a bad coil then? Thanks for your help guys.
T
tonytaylor85
126
Augusta GA
Oct 5, 2009
  • Oct 5, 2009
The coils would not cause spark knock. Try adding 2% more fuel with the tuner. If that doesn't fix it, pull timing @ 4k-8k. Depending on how much ethanol is blended in your gas, the fuel may or may not help. Timing will solve it for sure, but may cost some power.
Dark_Horse
83
Springfield, MO
Oct 5, 2009
  • Oct 5, 2009
Okay yah ill try adding fuel and see what happens then. This may be a dumb question, but how do you pull timing? I see I have a timing adjustment on the tuner, should I retard timing until the spark knock goes away? I'm really green when it comes to tuning so any help I can get would be tremendous.
bhuff30
6,037
35
129
Olathe KS
Oct 5, 2009
  • Oct 5, 2009
First, ethanol adds octane. I run E85 in my 2.3 and it has about 104 octane.... or enough octane for an 8:1 engine running 24psi and a 35 shot.
That rattle sound is most likely detonation. Detonation can sound like rocks in a can or like a hammer beating on your engine. Just depends on the severity.
It is possible it is from running lean in the upper rpms... maybe a weak fuel pump. It is also likely that your 93 tune is just a bit too aggressive and needs a little bit of timing pulled out. A few degrees of timing isn't going to make much difference on your engine.
T
tonytaylor85
126
Augusta GA
Oct 6, 2009
  • Oct 6, 2009
Ethanol has about 63% the energy per unit mass. Ethanol is heavier than gasoline so you end up with around 66% less energy per unit volume- which is what the EEC uses. E10 therefore has 6.6% less energy available at WOT compared to pure gasoline. Lean is lean and will cause detonation. 93 octane is 93 octane and you aren't getting anything for free from the gas station.
bhuff30
6,037
35
129
Olathe KS
Oct 6, 2009
  • Oct 6, 2009
I ran gas with up to 30% ethanol for several years in my 97 GT. The wonderful thing about modern ECUs, is that they can compensate for varying conditions and fuels (to a limit). Even with E30, I didn't get a check engine light. When I looked at the AFs, the lambda was identical to running pure gasoline, even at full throttle where the O2 sensor is in open loop: so not leaner and no change in power!
Yes, it has less energy, but that just means you need a little more of it. The computer automatically adjust it. My mileage was down about 1 mpg, but it was cheaper, so I was ahead.
Try it for yourself.
T
tonytaylor85
126
Augusta GA
Oct 6, 2009
  • Oct 6, 2009
The LTFT can only do so much. Why else would we need widebands and dyno tuning? I agree that a stock tune on a stock car is designed with varying fuel quality in mind, but the 93 tune he has is probably pretty close to the edge.
GDawg
1,469
Nevada
Oct 7, 2009
  • Oct 7, 2009
I love these kinds of threads...
jgorm
  • Oct 8, 2009
Check out this link. It will clear up a lot for you.
Detonation Explained
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
