I'd highly recommend anti-seize. I followed the Bullitt Archive write up - it's excellent. And even though I used tons of compressed air, there still seemed to be 'grit' (for lack of a better description) on the threads. So, what I did was smear a bit of anti-seize on the old plug and run it down by hand until I hit resistance. Then I backed it out, cleaned the threads, gave it more anti-seize and repeated this process until I could run it all the way down by hand. Then I installed the new plug. It was a time consuming process, but, IMO, worth it. With these aluminum heads, cross threading is a real concern.
