  • 1994 - 1995 Specific Tech
spark plug question
  • Thread starter Thread starter 331 stang91
  • Start date Start date Aug 30, 2007
331 stang91
261
wisconsin
Aug 30, 2007
  • Aug 30, 2007
I changed my plugs and noticed some of them were wet. Would this be probably oil blow-by or could it have been fuel that didn't burn off? The motor has 98000 on it.
bill302
2,131
alabama,gadsden
Aug 30, 2007
  • Aug 30, 2007
run a compression test and post results....click on links below for good info on compression testing...
http://www.pumaracing.co.uk/comp.htm
http://www.risaa.org/newsletter/0506/0506_12.pdf
331 stang91
261
wisconsin
Aug 30, 2007
  • Aug 30, 2007
Thanks I'm going to get the tester this weekend and do the test sometime next week. Any thoughts without having the test results? I was thinking it was most likely oil but hoping it might be a couple drops of fuel or is that just wishfull thinking?
go-stang5.0
2,244
Glenview,Il
Aug 31, 2007
  • Aug 31, 2007
Well was it black? Did it smell like fuel? That could give you a preliminary indication. How long did you wait to pull the plugs after running the car. Gasoline would evaporate pretty quickly in a hot combustion chamber.
The only time I have seen a car with fuel soaked plugs is when it cranks but doesnt start (and the fuel system is working) and you pull a plug shortly there after.
94-302-vert
1,947
NE CT
Aug 31, 2007
  • Aug 31, 2007
331 stang91
261
wisconsin
Aug 31, 2007
  • Aug 31, 2007
ya it would be oil then I guess I was just hoping it wasn't. The plugs did smell of fuel and the liquid was very clear but the oil is pretty clean. But I did have the car off for about an 1/2 hour or so so I guess the fuel would have evaporated. Thanks for the responses
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
