are bosch platnium +4 spark plugs any good??? they are quite pricey... and how do they compare to iridium?? thanks in advance!
They are trash, IMO. Never use them in your 5.0 or you will miss like a mofo.longfellowdeeds said:are bosch platnium +4 spark plugs any good??? they are quite pricey... and how do they compare to iridium?? thanks in advance!
I was being a little facetious -- Bosch makes more than just sparkplugs, and a number of parts on our cars. For example, the ABS. They're a pretty big company, I'll grant you that their spark plugs are garbage though.madams74 said:No it isnt. This company plays to the tune of ripping off the customers by making false claims. They abuse their name and allow people who are ignorant believe they are buying a superior product. This is abuse.
GreenMustangGt said:i heard platnim plugs take away 24 ft/lbs of torque on a stock motor, and add 1hp over ngk.,oo thats only if you have a bosch sticker on ur car tho.
Not to mention if the spark has choose between 4 electrodes to arc to then there's got to be some hesitation in it's quest to find the "path of least resistance" and some cross-arcing going on in there and that's gotta make the spark less powerful and cause some kind of resistance I would think.Speed_Demon1965 said:Bosch plugs suck. 4 electrode posts...please. The spark is going to go the only ONE post at a time so what's the point of 4 of them? About as bad as "splitfire" plugs. I would use a good set of Autolites or use some Iridiums. Iridiums may not do much for a stock engine, but their life is much higher than standard copper plugs.
