  • SN95 4.6L Mustang Tech
Spark Plugs
  • Thread starter Thread starter rmv2000gt
  • Start date Start date Nov 13, 2006
1 of 2 Next Last
R
rmv2000gt
10
  • Nov 13, 2006
I'm going to change the plugs on my GT since it has 60,000 miles on it. What plugs do you guys suggest?
Thanks, Raul
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 13, 2006
  • Nov 13, 2006
Motorcraft AGSF-32C gapped at .054
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Nov 13, 2006
  • Nov 13, 2006
Autolite 764's gapped @ .053
four six
506
Hobart, IN
Nov 13, 2006
  • Nov 13, 2006
+1234567 I have never heard a bad thing about these plugs.
BooWFO
991
Louisville, KY
Nov 13, 2006
  • Nov 13, 2006
Is there anything done to the car?
For mild power adder cars. ngk tr6's work well, of course I just tried out some autolite 103's and they are working well.
sgarlic
3,085
Nov 13, 2006
  • Nov 13, 2006
Be sure to torque them properly, and recheck the torque every so often after that. These things love to spit plugs back out of the holes if they aren't tightened properly.
P
Pennywise2
Banned
May 16, 2006
1,379
  • Nov 14, 2006
Motorcraft or Autolite spark plugs are the way to go on are cars.
the98stang
2,408
Clovis, CA
Nov 14, 2006
  • Nov 14, 2006
Please, for the love of God, torque them to 13 lbs, and DON'T use anti-seize. I cry every time I hear some one say they got spark plug blow out. Check the plugs every month too. Or at least every oil chang.
M
MBDiagMan
171
Lamar County, Texas
Nov 14, 2006
  • Nov 14, 2006
I have replaced ZILLIONS of mod motor plugs with no problems. Here is my procedure:
Blow out the plug well with compressed air BEFORE removing the plug.
Use the exact Motorcraft platinum specified for your particular motor.
Use a VERY THIN coat of COPPER BASED anti-sieze ON THE THREAD PORTION ONLY. The anti-sieze MUST be copper based. If you don't have copper based or you are too sloppy with it, then put them in dry.
Thread them with your fingers until YOU ARE SURE that the threads are started.
Torque them to 13 ft lbs.
Use dielectric grease on the plug boot or COP. At the auto parts store, they call this "tune up grease."
Don't run them over 60,000 miles max before changing them again. The plugs themselves can go seemingly forever without trouble. The reason you don't leave them in there too long is that the heat cycling can eventually sieze them in place. If you can't afford new plugs, then remove them, gap them and torque them back in place.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 14, 2006
#10
  • Nov 14, 2006
  • #10
The only things I would add to your excellent procedure are:
-clean and lube the COP boots with silicone spray to ensure they are in good condition and form a good seal for the plug wells
-only attempt plug change when the engine is stone cold
-check plug torque at next oil change
And I would disagree with "Use the exact Motorcraft platinum specified for your particular motor"
sgarlic
3,085
Nov 14, 2006
#11
  • Nov 14, 2006
  • #11
Not that I don't believe you, but I'm curious how do you know a customer has never had a problem after you changed them? Do they give you feedback on cars you did the work on? Like "Hey Bob, customer X came back with an ejected plug. Just letting you know." ?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 14, 2006
#12
  • Nov 14, 2006
  • #12
For a stock, or near stock car, this would by my suggestion as well. Cheap, reliable and plentiful.
M
MBDiagMan
171
Lamar County, Texas
Nov 15, 2006
#13
  • Nov 15, 2006
  • #13
Good catch! I forgot to mention that it is ALWAYS best to pull the plugs when the engine is as cold as possible.
If the plugs are torqued accurately, there is no need to recheck them. I used to do that when I had the opportunity, but never found a loose one so I stopped doing it.
M
MBDiagMan
171
Lamar County, Texas
Nov 15, 2006
#14
  • Nov 15, 2006
  • #14
Tell me something..... If YOU had a plug come out after they had been changed, would YOU NOT go back to the shop where they were changed?
In a shop there is a term called "come back." Whenever work comes back, it is the responsibility of the tech that did the work initially, to correct it. If it is something that he did wrong, he redoes the work for no pay. IN almost all cases "come backs" go back to the original tech. There is such a thing as keeping record of which tech did the work on which vehicle.
RandyStinchcomb
1,159
Randallstown, Md
Nov 15, 2006
#15
  • Nov 15, 2006
  • #15
MBDiagMan said:
Use the exact Motorcraft platinum specified for your particular motor..
??? why, platinums are overprice and way over rated let alone being junk
go wth a good copper core plug, I've seen way tooooo many plats loose ther platinum tip(s) from high speed/extended driving. there ok for grandpa or grandma who only drive a little and keep there car under the speed limit as for being a performance plug, plats are junk, dont waste the $$$ on them.
R
rmv2000gt
10
#16
  • Nov 15, 2006
  • #16
Thanks for all the information. I'l go with the Autolites and make sure they are torqued to 13 foot pounds.
Raul
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 15, 2006
#17
  • Nov 15, 2006
  • #17
No, the Autolites are made to a lower quality specification than OEM and also they have the short thread design, not the long thread design like the current AGSF series Motorcraft plug.
AGSF-32C you can get them at AutoZone.
M
MBDiagMan
171
Lamar County, Texas
Nov 16, 2006
#18
  • Nov 16, 2006
  • #18
The factory plugs are platinums. They hold up well.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 16, 2006
#19
  • Nov 16, 2006
  • #19
They're meant to. But they're the furthest thing from a performance plug. The stock plugs are designed for durability and meant to run long intervals between changes, but let me ask you.....who really waits 160,000km between plug changes? Mine are coming out at 60,000km no matter what they are, which is right where the copper plugs start to wear out.
ToplessStang
591
Montreal, Canada
Nov 16, 2006
#20
  • Nov 16, 2006
  • #20
Just bought new stock plugs. $30 for 8 Ford platinum plugs (employee price) isn't that expensive. As far as performance goes I haven't had a problem with them yet so I'm going to stick with them.
Don't fix what ain't broke.
1 of 2 Next Last
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
P
Resolved Spark plug location
  • Ptanner
  • May 17, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk May 18, 2026
Ptanner
P
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
