  • SN95 4.6L Mustang Tech
Speedo issue
  • Thread starter Thread starter MidnightBlk98GT
  • Start date Start date Jun 29, 2005
M
MidnightBlk98GT
45
FL
Jun 29, 2005
  • Jun 29, 2005
Does anyone know what the correct color and tooth count is required for the speedo gear that fits a '98 t-45 with 3.73's?
T
tjm73
2,418
Rush, NY
Jun 29, 2005
  • Jun 29, 2005
With stock size tires you would need a 24 tooth speedo gear. But no one makes it one. So 23 is as close as you can get.
But don't dispair, if absolute accuracy is what you want, you can get a Dallas Mustagn Speed-Cal speedo correcter for like $100 and it's infinitly adjustable without needing a different speedo gear other than what you already have in the car.
Chili
174
Euless, TX
Jun 29, 2005
  • Jun 29, 2005
Or buy a hand held tuner (like the Predator or Xcal) which can adjust for gear changes, tire size, etc.. Plus you get the other benefits such as tuning (duh), mil eliminators, shift point and pressure adjustments (auto), data logging, diagnostic code reading, etc.. Well worth the $350..
squares98
852
Orange,ca
Jun 29, 2005
  • Jun 29, 2005
98's have a mechanical speedo, the only options are a gear or a speed-cal. And like tmj said, you need a 23t gear.
M
MidnightBlk98GT
45
FL
Jun 29, 2005
  • Jun 29, 2005
Well, the reason I ask is that I had my gears put in about 3 years ago and when it came time to rebuild the tranny the 23 tooth (white) gear that was in there was all chewed up. I bought a replacement gear but now I'm wondering if the feeding gear, the speedometer drive gear, is the correct one that is in there. Any ideas??
Edit: Yes, the speedo sending unit rotates freely.
Chili
174
Euless, TX
Jun 30, 2005
  • Jun 30, 2005
Okay.. So I'm an idiot I didn't pay attention to the year.
T
tjm73
2,418
Rush, NY
Jun 30, 2005
  • Jun 30, 2005
It has been widley reported in the 5.0 end of the Mustang world that the 23 tooth speedo gear has roughly a 20,000-25,000 mile lifespan. They wear out quite a it faster than the other gears with fewer teeth.
J
jamez1502
Banned
Nov 6, 2003
135
Lakeland Fl
Jun 30, 2005
  • Jun 30, 2005
i have 4.10s and mine is 10mph off
T
tjm73
2,418
Rush, NY
Jun 30, 2005
  • Jun 30, 2005
You need this. Speed Cal
9
97gtblue
283
pensacola,florida
Jun 30, 2005
#10
  • Jun 30, 2005
  • #10
i have 4.10's and the new speed gear thing and its still off 10mph
T
tjm73
2,418
Rush, NY
Jun 30, 2005
#11
  • Jun 30, 2005
  • #11
Speed gear thing? Are talkling about the 23 tooth gear?
9
97gtblue
283
pensacola,florida
Jun 30, 2005
#12
  • Jun 30, 2005
  • #12
couldnt tell you.. ..its some kind of gear that went in my transmission
T
tjm73
2,418
Rush, NY
Jun 30, 2005
#13
  • Jun 30, 2005
  • #13
OK. Without going into a long disertation about what and why, the 23 tooth gear is as close as you can get, mechanically, to make your speedo correct. The Speed-cal will make it correct electronically.
9646gt
595
Holloman AFB,NM
Jun 30, 2005
#14
  • Jun 30, 2005
  • #14
my car has 4.10's (96gt) but the speedo sometimes wont work till you hit 80 and sometimes is way off (20+mph) and is never the same..do I have a broken speedo gear? If yes how hard are these to change and what do they cost...I have 275 40's in the rear
T
tjm73
2,418
Rush, NY
Jun 30, 2005
#15
  • Jun 30, 2005
  • #15
That could be an electrical problem, or a wornout needle spring, or something else. Speedo gears are cheap at about $15 bucks or so and are pretty easy to change. I doubt that's the cause baised on what you describe. I'd look for an electrical problem.
275/40R17 is the same height as the stock 245/45R17.
9646gt
595
Holloman AFB,NM
Jun 30, 2005
#16
  • Jun 30, 2005
  • #16
Great I love electrical problems..but if its a mechanical gauge what type of electrical problem could I have?
T
tjm73
2,418
Rush, NY
Jun 30, 2005
#17
  • Jun 30, 2005
  • #17
Starting in 1994 Mustangs got electrical guages. The output from the tranny is mechanical, but it goes to a box that converts it to an electrical signal that the dash uses to display your speed.
Unless you have installed a true mechanical speedo.....
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Drivetrain Autometer Speedo Cable for T5
  • cbac89
  • Feb 15, 2025
Fox 5.0 Mustang Tech Feb 15, 2025
AeroCoupe
F
Putting 1991 Hatch on 1986 Car - What Size/Thread Hinge Bolts?
  • frwgt350net
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Mcmahst
