Spent 3 hours trying to figure out converting my jelly jar M/C to a dual reservoir M/C on my a-code '65 disc/drum
1320stang
4,321
20
89
Edmond, Oklahoma
As it says in the title, the car came factory with the Kelsey Hayes disc brakes. We're finally trying to get this thing moving under its own power for the first time in a quarter of a century. I'm trying to recall if it was running when I joined Stangnet.....
Anyways, we're (my 20 year old son and I) trying to get this thing moving under its own power by his 21st birthday which is less than two months away. I have acquired an '88 LTD 302/AOD that ran when pulled as well as an Explorer intake, and wiring harness, although we may just throw the 4bbl cast iron intake and a 600cfm Holley or the 4100 on there for now. Not trying to drive it on public roads, at least not out of our neighborhood (we live in the country, our side of the neighborhood only has one entrance and leads to 3 cul-de-sacs, one of which is a little over an 1/8 mile). I figure getting it moving under its own power will help motivate him. The 302/AOD is just a temporary means of propulsion, but if it moves, it needs to stop. I had stripped a '93 Mustang GT many years ago and had considered trying to use that, but it looks to be a bit more work tying it all in, the money saved will be spent in time and effort and I'm finally getting old enough that its not worth it.
He'd like to rebuild the original engine and pretty much make it stock, or at least stock appearing, a dual M/C is just a safe and reversible upgrade.
Most everything I've found is for power brakes which we don't want as usually they only work with automatics and this car originally had a three speed. I'm guessing the booster interferes with the clutch rod. Most everything manual is for drum/drum, or its just an ambiguous description. Maybe I'll just get a new jelly jar and when we get to the point it gets insured and tagged we'll change the brakes up.
After typing all this and searching on another screen, I found that Virginia Classic Mustang has a '65-'66 Dual Reservoir Master Cylinder Conversion Kit for Front Disc Brake or 4 Wheel Disc Brake (this worries me a bit) equipped cars, Item # BK3381 for $94.95. It comes with a 1" bore M/C, brake lines to attach to the factory 3 port distribution block, a plug for the distribution block as well as a union for connecting to the rear brake line. Now I see CJ Pony Parts has the same kit for $109.24 DBC3 or $119.24 DBC4, not sure of the difference. Just looking for simple and relatively inexpensive in case we change, but worthy of a permanent install. Its not planned to be a hot rod. Has anyone used one of these kits on their factory disc brake car?
I have not installed that kit. I did install an '86 SVO aluminum dual bowl MC on a previous '66 mustang of mine though...looks stock-ish and is far lighter than the cast iron dual bowl. Some dual bowl MCs come with a residual valve meant for front disc/rear drum setups...but just to be clear, a residual valve is not technically needed for front disc/rear drums, it does help with pumping losses and gives marginally quicker engagement of the rear shoes, but with well-adjusted rear shoes you wont even notice the difference. Yes, you should use a residual valve if using front discs and rear drums, but you can get away without it. That being said...a lot of early MC had the residual valve built in...later on the regulations changed and they started placing the residual valve externally(sometimes even at the rear axle tee) Speedway has a good article on brake systems geared toward front disc/rear drum:
In this case, they used a residual valve on both circuits...the front residual valve is much weaker than the rear valve to prevent the calipers dragging on the rotors.
All that being said...I simply wouldn't bother for a cruiser. Everyone always says the fruit jar is unsafe, etc etc...but the reality is that a dual bowl MC is only BARELY safer than a single bowl. The reason is simple, If you spring a leak in a single bowl master you lose all hydraulic pressure and 100% of your braking ability and if you only notice this when you are driving along at 80MPH and have to slam on your brakes, you aren't going to stop. If you spring a leak in the front brake circuit of a dual bowl master...you only lose 80% of your braking power...if you have to slam on your brakes, you STILL aren't going to stop before hitting something, you will just hit it 20% slower. That 20% might be enough to make a difference...or it might not. In the end, I have never heard of a fruit jar MC failing catastrophically and have rarely heard of ANY MC failing catastrophically. In a true brake system failure you are better off trans-braking and using the E-brake than you are standing on the brake pedal anyway(at least in a manual trans car)
Not sure how old you are @wicked93gs *, but I lived at the tail end of the single bowl MC era (I'm a '65 myself). You haven't heard of it because we've been out of that era for a long time, and we've become pretty spoiled over the last 50 years with ultra-reliable brakes. But they didn't used to be ultra-reliable. They failed often enough that automotive engineers decided to make dual bowl MCs standard equipment.
*Not intended to sound condescending
disc frnt is great. Mark VIIIIII or sompin MC fits FW holes & brake pedal PR, so direct swap in. Has frnt LARGER resovour (disc needs more) and a 2nd for back. No confusion w/PB, booster'n all that. No residual valve or proportioning valve.
I have an ol bronco so not directly applicable (more falcon like) but that's what I did. Swapped ina axle (frnt) w/the dana 44 chunk which has frnt discs but some use the early ford luxury (like I did for MC) for the rotors'n calipers...
This is Y I come here. The fellas can ID 4 us what Y/M/M is the application. The fancy Kit builders (CJ etc) just take these same prts, clean'n paint, assemble & tripple the price 4 us. If ur handy go 4 it ! Skip the kit, get acc the desk of any big box auto prts retailer. 30 yr old prts, brand new, on shelf @ autoZone, no order'n wait...
I'm just planning on a more factory looking M/C, like maybe the manual 1967 Mustang M/C for disc/drum especially since they were still the K/H 4 piston jobs like I have.
Speaking of which, I plan on rebuilding them, not sure of the quality of the cups right now, but lets say they're okay for argument sake. It seems rubber quality has gone to the crapper in the last couple decades, what is the best rebuild kit to get? Napa has a boot and seal kit for $20.99 for one caliper, part # UP518.
Well, I had hoped to have this thing running by the 2nd of Nov but it doesn't look like that's going to happen. Cherry Picker on back order but I've been busy trying to get my '73 F-100 back on the road, this week will be it's maiden voyage legally on a street in over a decade, going to the carwash to clean under the hood and chassis, got to figure out where the C6 is oozing from, I'm afraid its the shifter shaft. Then its first public run will be for Trunk or Treat at our church. The scene will be Linus' pumpkin patch.
I hopefully have a set of original 1965 frame mounts to pick up and Coffee and Cars on the 6th. The Cherry Picker should be in by next week too. I'm taking off tomorrow thru Friday and I may tinker with the car a bit, putting valances and bumpers back on, mainly to find all the fasteners. Bolt the seats back down, put the interior handles back on and put the cluster, radio and glovebox back in, so it sorta looks whole(er) as well as finding the fasteners, its been apart probably 25 years.
Well, finally trying to get back onto this project. The motor mounts never came thru, so Friday I saw where AutoKrafters had a set for a '65 for $50 off, normally $229, now $179. So I ordered, aaaaaaannnnnnnd they're backordered...... Site says normally 2-3 weeks, hoping that doesn't turn into 2-3 months, or years... Why advertise them as being on sale if you don't have any?
Anyways, Halloween was a hit, Cherry Picker cam in and it had some miss drilled holes so I had to take it back and swap it out. Then loaned it and the engine stand to a buddy. Christmas season came, therefore Santa season came, I tested positive for Covid on the 23rd and had to cancel my last two Santa gigs. It wasn't bad, just like a mild cold, slightly runny nose and the trots for a few days (that was the worst part), no loss of taste or smell, but have been feeling pretty lethargic since. Couple that with the fact that our winter has been crazy, we've had 20's and snow followed a couple days later with mid 70's and sunny, then back to teens and ice. I'm old enough that my body doesn't acclimate to weather changes as well as it used to.
I need the motor mounts to come in because I want to store the engine where it'll end up as opposed to on the floor in my garage.
Called AutoKrafters at lunch, apparently they had the parts in stock and they're on their way. I told her the invoice didn't make a lot of sense to me, she said the computer doesn't know shipping can't be back-ordered. So maybe they'll be in by the weekend, then I just need to go arrange picking the motor and trans up.
Jimmy Christmas, I just think I'll never get back onto this project.
Was thinking I was so close to getting the shop build started last year, finally tomorrow a guy is coming out to remove trees and the root balls.
My company got bought out last year, knew it was coming about 6 months before the end of the year, so I kinda put stuff on hold just to see what would happen, it all seems good now. Caught covid in the middle of my Santa Season and it cost me some pretty decent paying gigs.
Then the world stopped on Sunday January 29th, my 82 year old father passed of a heart attack, he had been at work on Friday (works out of a pickup for a oilfield welding company that also does dirt work and concrete work, basically bid jobs and went out and check on them,) and had just been to the heart hospital on Wednesday where they said other than his AFIB he looked great, come back next year.
They lived a little over an hour away from my sister and me (we live about 6-7 miles apart) and mom wants to move down closer to us. We've been spending every weekend going up and moving stuff to storage, tossing stuff, bringing stuff home to get the house ready to sell. Its an ordeal, mom doesn't know what she'll do once the house sells, but for now she's busy. She doesn't even want to look for a place until she knows how much she'll have to spend, and we're in a more expensive place than where they were.
Now that its nicer and the days are longer I need to at least get the motor and trans stabbed so I gain the room in the garage and I'm not tripping over it. I picked up a 2006 CV last year with title as a parts car for my son's 2005 CV, we got most of everything off it we need, just need to swap the passenger fender. The 2006 need a rear end in it, other than that, it runs and blows cold air. Need to get a rear axle and sell it.
Good to see your still busy Larry.
I recently lost my Dad also, he was 91.
I've yet to get back to my '65. Stuck in storage before COVID hit and never got back to pick it back up.
