Spring Cleaning...somewhat
  • Thread starter Thread starter McQueens Dream
  • Start date Start date Apr 12, 2007
McQueens Dream
260
Winston Salem, NC
Apr 12, 2007
  • Apr 12, 2007
ok, not really cleaning, but getting started on my fox soon. it's a 5.0 91 LX hatch AOD, has 176K on it, all factory stock, it even had the air silencer in it when i bought it. i don't have a ton of money invested in the car, and don't plan to invest a lot either. i do want it to look a little nicer than it does now, but all it needs is some trim and a GOOD cleaning...anyway, it is time to start tuning it up real good, and i bought a bunch of stuff yesterday, and have a few more things to get, but this should get me rolling pretty good for a while:
5% tint is being done tomorrow (4/13/07)
new Monroe struts and shocks
plugs/plug wires
distributor cap/rotor button
oil and filter
fuel filter
serpentine belt
180 t-stat
speedo cable
still got to get:
fuel pump
the sensor on the distributor, can't remember what it is called...
"B" or "C" coil springs
i could probably go on and on, but like i said, i am not going to invest a lot of money in this car, it's basically a beater we drive to keep from getting my wife's 2006 GT beat up in parking lots and whatnot...at least it will be more presentable with this stuff...let me know if there's anything else i should change, it already had a new water pump/radiator hoses and radiator on it when i bought it, they are only about 1 year old now...
goodfastncheap
100
Bellevue, NE
Apr 12, 2007
  • Apr 12, 2007
Congrats on finding a factory stock Fox!
Few things I might do. Clean all your grounds, clean battery cables and test for voltage drop, check all wires underhood for good insulation and tidy connections. Replace vacuum lines if they look dry. Maybe replace ALL fluids, PS, Trans, brake, rear, coolant. Check all your bushings.
After you do this and all the other MECHANICAL things you listed, THEN start buffing and waxing.
Fun "Beater"! Probably won't be for long. "Beater" that is!
McQueens Dream
260
Winston Salem, NC
Apr 12, 2007
  • Apr 12, 2007
thanks...but yeah it will be a beater for a while, this is the 5th fox i have owned and my wife has an 06 to play with, so mine will stay a beater, unless i win the lottery...
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
