  • 1994 - 1995 Specific Tech
stalling after tfs intake install
  • Thread starter Thread starter 302fordracer
  • Start date Start date Apr 18, 2005
302fordracer
738
Vancouver, WA
Apr 18, 2005
  • Apr 18, 2005
Ok this is kinda long but I would really appreciate help...I got a brand new tfs street heat installed in december of last year..they had a very difficult time getting the car to run afterward...the computer didn't like the intake..they turned up the fuel several times and the comp kept resetting it. They turned it up because the car would start and run but everytime you stopped at a light it would instantly die..well they swapped out my computer for an aftermarket one and turned up the fuel 15% and changed the time the fan comes on to 180 degrees..well after doing this it would run right most of the time but it would still occasionally die at street lights..after driving it awhile the problem went away and the car ran really good cept I really did notice much gain (thinking maybe the tune still isn't strong enough)..now everytime I remove the battery the car stalls at lights occasionally for a week or so until the computer figures out how to make it run..I am thinking about going and getting a dyno tune (even though I don't yet have a cam)..what do you all think about this..(when they were trying to get it to run they didn't have a dyno they were using simple hit and miss technique)...Does it make sense to go to the dyno and see if they can make it stronger and deal with the battery removal running issues??
302fordracer
738
Vancouver, WA
Apr 18, 2005
  • Apr 18, 2005
btw they did reset the idle...I was standing right there during a major portion of this install..and I trust their work they are a very well known and very trusted shop in this community...everyone with a stang goes there and all the techs own modified stangs
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Apr 18, 2005
  • Apr 18, 2005
The intake install shouldnt need a tune at all. Have you double checked all of the vac lines? made sure all of the connections are good and everything is sealed? I wouldnt waste the money on a dyno tune when its something else causing your problem.
302fordracer
738
Vancouver, WA
Apr 18, 2005
  • Apr 18, 2005
well it runs fine...it just stalls after battery has been removed for a few days..then the problem goes away and all it peachy..
brentwoodboy
472
Brentwood, TN
Apr 18, 2005
  • Apr 18, 2005
Thats funny, I just did mine myself, and all I had to do was retime it
S/CBlack95GT
2,018
Tampa Palms, FL
Apr 19, 2005
  • Apr 19, 2005
When your car is idling, reach down and unplug the IAC connector. If the car dies then they did not reset your idle properly. IM me and I will tell you how. Stalling after installing an intake is common. You have to reset the idle right to cure it.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
