stalling problem
  • Thread starter Thread starter 91fox50
  • Start date Start date Sep 27, 2007
9
91fox50
long island, ny
Sep 27, 2007
  • Sep 27, 2007
i have a 91 gt, with a stock motor. when u firt start the car it runs great, after about 15 mins or so a check engine light comes on, and it will continue to run fine until im sitting in bumper to bumper traffic and then the car suddenly starts to run like crap and then stalls. and if i try to start it again it will eventually start but immediately stalls after a few seconds. if the car sits for about a half hour i can start it and it will run fine, i guess because the code clears itself after a while. i havent done anything to try ro fix it yet. any info about the problem would be greatly appreciated.
302RollinHard
Columbus, OH
Sep 27, 2007
  • Sep 27, 2007
pull the codes to see what it says. My money is on a TFI........
HISSIN50
34
129
Sep 27, 2007
  • Sep 27, 2007
My thoughts exactly.
You can have the TFI tested at the parts store. In your case, have them test it repeatedly to heat it up (a TFI's critical temp is ~257*F).
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 28, 2007
  • Sep 28, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
9
91fox50
long island, ny
Sep 29, 2007
  • Sep 29, 2007
thanx alot for the info on how to check codes, im new to these cars and i wasnt sure how i could do that on my own.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
G
Its starts then stalls
  • gray owl
  • Jan 22, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 25, 2026
gray owl
G
