  • SN95 4.6L Mustang Tech
Start issues?
  • Thread starter Thread starter cookcr
  • Start date Start date Sep 11, 2007
C
cookcr
Brighton Colorado
Sep 11, 2007
  • Sep 11, 2007
Sometimes when i fire up my car it starts right away, sometimes i have to crank a little while for it to turn over(nothing major just enough to know somethings wrong). I was told it was the fuel filter, any other ideas? Dont want this thing to crap out on me, my trucks out of commision for another week on a new build so i dont want to just dig in and tear it apart right now till i have another vehicle.
BobHyatt
378
  • Sep 11, 2007
hook up a fuel pressure gauge to the valve on the fuel rail. When you turn the key on does it jump to 40+ psi or does it stop at 8-10? If 8-10 does turning it off and back on again run it on up to 40? Fuel pump is getting ready to go out if so.
Best way to diagnose is to measure things. Guessing can get expensive and frustrating. If the motor turns over normally, but sometimes takes longer to fire up, it is almost certainly a fuel issue. Pump is the first thing that comes to mind, not the filter. If pressure is low at the rail, you can always check the flow before / after the filter to see if it really is clogged. But most of the time its going to end up in the tank (the pump)...
stangg01
129
  • Sep 11, 2007
I had a similar problem. I cleaned my IAC (Idle Air Control) valve. I've had no issues since.
Cleaning the IAC valve is really easy. Do a Google search for instructions.
Superhereaux
chicks make me feel inadequate
538
South Texas
Sep 11, 2007
  • Sep 11, 2007
does it only do it when the car is already warmed up?
like gassing up for 5min. then restarting?
1Phat5Liter
37
Los Angeles, CA
Sep 11, 2007
  • Sep 11, 2007
How's your battery/charging system?
C
cookcr
Brighton Colorado
Sep 12, 2007
  • Sep 12, 2007
My battery/charging seems just fine. It will do it after its been running for a while, take a trip, shut it off and when i start it, it will do it sometimes. Should be able to check fuel pressure tommorow.
the98stang
2,408
Clovis, CA
Sep 12, 2007
  • Sep 12, 2007
You have to let the fuel pump fully turn on. So put the key in the ignition, turn it to the on position, and WAIT until you see the digital odometer (or until the radio turns on). Then try to start the car. See if it does the same thing.
steve_stang2003
195
  • Sep 12, 2007
It seems to be a common problem with these cars.
Mine used to do it on restarts, like the car is warmed up, I turn it off for a couple of minutes and then restart.
Now I turn the key to on, put on seatbelt etc and THEN try and start and it fires up every time.
streethorse
1,042
Dallas Texas
Sep 12, 2007
  • Sep 12, 2007
If the fuel filter and battery are original from 2002 they both need to be replaced.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Sep 12, 2007
#10
  • Sep 12, 2007
  • #10
ahhhh the good old hot start problem these cars have....well i have done the fuel filter, cleaned the IAC valve went away for a while but now it only does it occasionally .........and yes i do wait for the system to prime everytime
281CI96Coupe
233
#11
  • Sep 12, 2007
  • #11
Yeah what is up with the "the hot start problem" why does it start nice cold, start funny hot, I dont get it?
wilsonc2222
32
texas
Sep 13, 2007
#12
  • Sep 13, 2007
  • #12
fuel pump
my car stopped on me sunday. i think its the fuel pump. after sitting for about
30 minutes. it started. i had no pressure at the fuel rail. now i have thirty psi
when its running but as soon as i turn the key off it drops to zero. i called my local
ford dealer and they said it could be the fuel pump, fuel pressure regulator or the constant control relay module. my car started doing like yours and it got to where
i had to cycle the key on and off 3 or four times before it would start. i disconnected the vacuum hose from the fuel pressure regulator and the pressure
went from 30 to 40 psi. i think its the fuel pump or the CCRM. i'm changing the fuel pump first. ford wanted $99.00 to tell me what the problem is. i may be sorry
but i'm going to change paarts until i fix it
BobHyatt
378
#13
  • Sep 13, 2007
  • #13
If pressure drops to zero immediately, it is likely the pump. It certainly isn't the CCRM. That's just the thing that contains the fuel pump relay. The relay contacts can burn, which will reduce the current flow to the pump, which will reduce pressure or flow rate. But it is supposed to hold pressure when the key goes off. For minutes not 1 second...
blstang
26
#14
  • Sep 13, 2007
  • #14
that worked for me when i had problems myself on my 04.
Superhereaux
538
South Texas
Sep 13, 2007
#15
  • Sep 13, 2007
  • #15
but i'm going to change parts until i fix it
throwing parts at a car is the worst thing you can do time and money-wise to fix a problem
i could go on for DAYS telling you why and giving examples but i'd prefer to watch TV instead
40oz
499
Minneapolis
Sep 14, 2007
#16
  • Sep 14, 2007
  • #16
I've noticed that when I've been running the AC, the car takes an extra second to start when hot. Leaving the key in the on position for a minute doesn't help. If I haven't been running the AC or the car is cold, it starts right up. All I can guess is the the AC compressor clutch is still engaged or there is some other load preventing immediate starting. Not something I'm willing to pay to "fix" at this point, however.
No way I'd start swapping parts without a diagnosis from an expert who actually looked at the car, i.e. a Ford dealer tech. And at that point, I'd rather pay them to fix it right than keep running around until the problem is solved.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Sep 16, 2007
#17
  • Sep 16, 2007
  • #17
steve_stang2003 said:
+1
Yup, VERY common problems on these cars.
I do the same thing now. Turn key to on, let the fuel pump cycle for a couple seconds and then crank it and it usually helps.
I've heard it's IAC related, but i haver yet to try to clean mine
the98stang
2,408
Clovis, CA
Sep 16, 2007
#18
  • Sep 16, 2007
  • #18
Are you starting the car with the AC on? That would cause more load, making it harder for the car to start.
Maybe your battery is slowly dying? Only other thing I can think of is your injectors/fuel pump are having a hard time at start up.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Sep 16, 2007
#19
  • Sep 16, 2007
  • #19
The A/C does not come on when you start the car.
If you have the selector in A/C, the car will start without engaging the compressor.
Once the engine is running, there is a delay of about 2 seconds before the compressor kicks in. If you have the windows down you can hear it click on afterwards
BobHyatt
378
#20
  • Sep 16, 2007
  • #20
Should not hurt cranking at all. PCM turns compressor off until engine is cranked and running.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
