start up problems still!?!
  • Thread starter Thread starter jcwhite1288
  • Start date Start date Nov 1, 2006
J
jcwhite1288
38
  • Nov 1, 2006
Im having a problem getting my 66 to start consistently. sometimes it fires up strong, other times i sit there and can listen to my starter slowly turn. i thought it was the connections so replaced those but it still does it.. my battery doesnt seem to be either holding a charge or isnt recharging correctly
i have a new starter so its not that
i have replaced my alternator, battery, my bad electrical, and i re grounded my alternator.. and it still dies on me. my friend suggested i get a new voltage regulator but i dont see how that could help but im getting desperate..
help anyone?
D
drbobj67
59
  • Nov 1, 2006
You may have already tried these but here goes. Test the voltage and see if the battery is holding the charge. Just because you have a new starter and alt don't assume that they are not the problem espec if they are rebuilt/reman, never hurts to bench test them. I had a so called reman starter that was bad.
When you say you replaced bad electrical i assume you mean cables if not check them. Then there is the old trick of once your sure you have a good charge on the bat leaving it unpluged overnight and then see how it starts in the AM. something may be drawing charge.
D
D.Hearne
11,730
south louisiana
Nov 1, 2006
  • Nov 1, 2006
Got Points? If you still do, that's a MAJOR problem area in as far as quick starts are concerned.
J
jcwhite1288
38
  • Nov 2, 2006
what do you mean points?
im thinkin that my regulator is bad and its sucking my battery.. but im not sure.
anyone else have any suggestions?
D
D.Hearne
11,730
south louisiana
Nov 2, 2006
  • Nov 2, 2006
Talking about the breaker points in the distributor. BAd points or off tune = hard starts. Hard starts = longer cranking time and more drain on the battery. Had a few old Ford's that needed a jumper wire to "hot shot" the coil to get em to start.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
martroy
M
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
