Starter problem...need help PLEASE!!
  • Thread starter Thread starter my93_coupe
  • Start date Start date May 26, 2010
M
my93_coupe
  • May 26, 2010
ok here it is....I have a 1993 5.0 coupe, my problem is that when I run my car to a good temperature, and then shut if off and come back a few minutes later it doesn't want to start.... it makes a loud streching noise that comes from the starter....it's not till it cools down some it'll turn over.
Now this is what I've done....I have replaced the starter twice to oems (brand new), bought a brand new mini starter and wrapped it with a a heat wrap and still the same problem...replaced the solinoid and the wiring that runs to the starter...still the same thing...and replace both battery cables still the same. The alternator is getting a charge and the battery is good.
I just don't know what else to do...if anybody knows or has had this problem...I would love to get some advice on how to get fix my problem
J
jka
5 Year Member
Jan 17, 2010
339
23
29
May 27, 2010
  • May 27, 2010
Have you looked into the ignition wiring or the ignition switch. It sounds like something is getting to hot like your wiring or your ignition switch. Not the switch you turn and start the car with but the one that sends fire to your system when your key is turned.
D
Daves94vert
113
May 27, 2010
  • May 27, 2010
What do your grounds look like? Replace your grounds and add an extra one(engine to chassis). Make sure when you add you have metal to metal contact. Use a piece of sandpaper and scuff the contact areas( both engine and chassis).
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
