Starter problem
  • Thread starter Thread starter yelbigbirdlow
  • Start date Start date Feb 11, 2008
Y
yelbigbirdlow
71
DFW Texas
Feb 11, 2008
  • Feb 11, 2008
when i start the car the starter won't stop cranking unless i disconnect the battery cable. ignition switch is good. the starter relay is good. had the starter test and it was said to be good. what could it be?
Fett
766
  • Feb 11, 2008
Starter relay is not good, it is sticking. Replace it. Better yet, replace the starter with a 95, 5.0 starter, add a trigger wire, and move the battery cable to the other relay post. Do a search for "95 starter", you should find a lot of threads detailing how to do it. I did mine a long time ago when my relay started sticking and just forgot the exact steps.
IIRC you move the battery cable to the other relay post and run a wire from the post the battery cable was originally on to the "Extra" prong on the new starter.
93 LX
3,081
Norwalk, CA.
Feb 11, 2008
  • Feb 11, 2008
wired wrong???
HISSIN50
34
129
Feb 12, 2008
  • Feb 12, 2008
If the solenoid is sticking (the common to normally-open terminals have continuous continuity), a new solenoid is needed even if the newer starter is used.
If pulling the S-terminal wire off the solenoid doesnt make it stop, I like the stuck solenoid idea. Sometimes the contacts tack together, especially if the battery is half dead when trying to start the car or it's cranked excessively.
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
