Starter problems
  • Thread starter Thread starter bigvino
  • Start date Start date Sep 8, 2010
bigvino
259
Corpus Christi, TEXAS
Sep 8, 2010
  • Sep 8, 2010
hey everyone, ive been having problems with my starter. heres the dilemma;
when i hop into the car and i turn the key, and 1 of three things happeneds..
1. car struggles to turn on. after turning the key, theres like a 2-3 second delay..and finally it turns on.
2. one loud click. which i know is the ground. but the starter has 2 grounds connected to it. i placed a 6g wire from the negative terminal on the battery to bottom of starter.
3. Car doesnt turn on. and i jack the front of the vechicle and locate the starter and wiggle the "signal" wire that comes from the starter relay. that usally turns it on.
I thought it was the ground at first, fix that, and i still have a problem.. maybe the vibration from the car is moving the "signal" wire.
I replaced the Starter Relay as well... thanks everone!!
bigvino
259
Sep 8, 2010
  • Sep 8, 2010
anyone??
W
wv109323
100
Lenore ,WV
Sep 8, 2010
  • Sep 8, 2010
Starter problem
First the wires going to the starter are positive wires coming from the battery. One carries the "load" of the starter motor and the second is a solenoid wire that engages the gear of the starter motor with the flywheel.
Go the the starter relay on the left fenderwell and short out the two bolt terminals. The starter should turn the motor over but should not start. (make sure the ignition is off and the car is out of gear if it is a manual transmission.)
If the starter rolls over, then the starter and wiring to it(from the relay) can be counted as good and the problem lies within the fenderwell relay or the ignition switch. If the starter does nothing then the problem can be in the wires going to the starter.
It sounds like that if you can wiggle the small wire going to the starter and the car starts then there is a intermittent connection from the fenderwell relay to the starter solenoid terminal.
You should hear the contacts click in the fenderwell relay when the ignition switch is rotated to the start position.Have someone turn the ignition to the start position and listen to the relay.
A test for the fenderwell relay is to use a jumper wire and short out from the positive terminal on the battery to the coil wire on the fenderwell relay. The coil wire is the terminal that has the push on wire with a 90 degree terminal. This also should supply voltage to the starter and the motor should roll over. If not bad relay.
Clean the battery terminals also.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 9, 2010
  • Sep 9, 2010
No Crank checklist for 5.0 Mustangs
Revised 09-July-2009 to reorder stuck solenoid help.
No crank. slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a know problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstuck and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See Automotive Test Tools for help for help troubleshooting voltage drops across connections and components. .
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
